Stainless Brake Lines
Old Sep 6, 2016 | 11:25 AM
G1HQ's Avatar
G1HQ
Hello all...
Wanted some feed back on Stainless Brake Lines.
What brand did you get and why?
How much of a difference did you experience with the addition of them ?
Im looking at ECS and Stoptech...
Thank you for your help.
Gabor
Old Sep 6, 2016 | 11:41 AM
deanjohnson's Avatar
deanjohnson
Originally Posted by G1HQ
Hello all...
Gabor
I just installed the ECS ones on my R56 this past weekend. They were easy enough to install with the correct grommets and proper length. The real deal clincher for me was the plastic outer sleeve.
I know it seems like a minor point, but stainless lines are typically a PTFE inner tube with stainless braiding around the outside for reinforcement. With the braiding exposed to the outside world, small stones, sand, or other gritty substances can work their way into the braids, eventually coming in contact with the inner PTFE tube. Over time this can lead to the tube being perforated, resulting in a failed brake line. On a track car where the lines are regularly inspected, and the vehicle is subjected to lower mileage, this is not as big an issue. On a road car where the brake lines are installed and forgotten about for the next 5 years, that can be dangerous.
I installed Goodridge lines on my 2002 SVT Focus a few years back and used some heat shrink tubing to make my own outer cover for the braided lines. I've had them on my Focus for 4 or 5 years now and have never had an issue, so the DIY route is a good option.
The ECS ones though are going to be cheaper than buying the lines and the heat shrink tubing and installing it yourself though.
As for performance, I only drove the car for a few minutes yesterday. In normal mode the pedal feels about the same as before I changed the hoses. When I put the car in "sport" mode, the pedal definitely firms up. I do need to go back and recheck my bleeding and make sure I got all the air out.
Old Sep 6, 2016 | 01:15 PM
Thanks for the order, I run the GP2 brake lines on my R58 GP2 BBK kit. And also on my r52 I have them. Easy to fit and exact match. Free ship also.
www.ecstuning.com
Old Sep 6, 2016 | 02:25 PM
G1HQ's Avatar
G1HQ
Thank you for the info, and thank you ECS too ..
Gabor
Old Sep 7, 2016 | 05:20 AM
Welcome.
Old Sep 7, 2016 | 09:13 AM
G1HQ's Avatar
G1HQ
Ordered ECS lines yesterday....
Old Oct 20, 2016 | 07:00 PM
Bster13's Avatar
Bster13
Steel braided lines are for looks only....and then they sit hidden behind your wheels. :p
hernlui
Jul 24, 2016 09:39 AM
Rebeccaj75
Apr 21, 2016 08:37 PM
2Inoneyear
R60/R61 Stock Problems/Issues
Apr 20, 2016 04:01 AM
MAGICIAN
Apr 3, 2016 02:02 PM
