Paint Code for R84 Xlite wheels
Old May 12, 2015 | 06:59 AM
TBRoye's Avatar
TBRoye
Does any body know or know where I can find the Paint Code for the R84 X Lite Wheels? I am getting ready to buy a set and they have some rash on the lip. Not bad as far as I can tell but will need to be touched up after clean up and some sanding.
Tom
Old May 12, 2015 | 07:10 AM
JAB 67's Avatar
JAB 67
Same question but for the S-lites. Probably the same color as the R84, but not sure.
Old May 20, 2015 | 11:20 AM
JAB 67's Avatar
JAB 67
bump; anybody got an answer to this question?
Old May 20, 2015 | 11:26 AM
Capt_bj's Avatar
Capt_bj
this is the paint code and the Sherwin Williams automotive formula code for
MINI wheel bright silver metallic
A54 79742 Wheel Brt Silver Met
any automotive paint supplier can mix the proper color with this information
for small batch work I like
http://www.automotivetouchup.com/index1.htm but you may have a local house that can fix you up . . .
note that as a PAINTED wheel this is a two part paint system .... SAME AS the body .... so you want the color BASE COAT and then need to top with clear . . .
the base will not have gloss or strength ... these come from the top coat . . .
previously posted btw .... search works .... that's how I found my old post(s)
SW lists no wheel entries after this one, which is several years old. Dunno if MINI isn't providing data or what, but I searched ALL MINI paint colors in their catalog and no more recent wheel colors are there
Old May 20, 2015 | 11:31 AM
TBRoye's Avatar
TBRoye
Capt.
That is what i have found. Bavarian Autosports has a kit but only one color is listed. Automotive Touchup doesn't have a color listed I would have to give them the code that you gave and see what they can do.
Tom
Old May 20, 2015 | 12:23 PM
Capt_bj's Avatar
Capt_bj
yes,
give ato' t/up the code and they'll mix it .. that's the idea.
And you might have a local mixer willing to do a small batch or rattle can.
A small bottle of brush on is pretty inexpensive for a color test . . .
another option or if this color doesn't match ....
a 'real' auto paint house has a computer matching system just like the ones you see at Home Despots or Lowes for house paints. The auto one is typically a hand held laser gizmo. It works .... when I bought my 79 I had no idea what the color was other than being SURE it was not an original Mini color. ZAP and I now have a formula I can take to any mixer and it matches pretty darn good.
Check around ... within 15 miles of me there are PPG, Sherwin Williams and Dupont store fronts for AUTOMOTIVE PAINT . . .
sevin
Feb 1, 2016 11:30 AM
Powershift
Aug 16, 2015 05:14 PM
Dashdog
Aug 10, 2015 06:17 AM
O4mcs
Aug 6, 2015 05:42 AM
