Questions about fitment
Old Mar 23, 2015 | 06:39 PM
gfx's Avatar
gfx
I am currently looking at some volk gtu bbs, 17.7.5+50 5x114 bolt pattern, I was wondering, if i purchase the adapaters from 4x100 to 5x114 will I have any clearence issues on a 2004 mini cooper s? many thanks in advance.
Old Mar 24, 2015 | 06:25 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Using a wheel hub to wheel adapter to change the bolt pattern from 4 to 5 holes will add some width like a spacer would, at least 19mm more poke.
Adding that to the offset of the 5 bolt wheel would give you even more poke. Using stretched tires or excessive negative camber would allow somewhat of a semi flush fitment but it would be extreme and even worse with a very wide wheel.
Check with this site and ask them-
http://www.motorsport-tech.com/wheel_adapters.html
If you lower your MINI then you get even less clearance, combined with a wider than 7" wheel and you will make things worse unless you choose a tire diameter that is much smaller than 24" (OEM is 24.4" tall).
donniedarko
Oct 21, 2015 01:15 PM
Panik
Sep 9, 2015 08:36 AM
