17x8 ET35 wheels?
Old Jul 28, 2013 | 11:50 AM
trithumb's Avatar
trithumb
17x8 ET35 wheels?
I am looking at a 17x8 et35 set of wheels. tossing a 205/40 on there. Would it fit on my 04 r53?
Old Jul 30, 2013 | 07:05 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Using stock suspension it should fit.
Compared to stock 17x7" wheels, the 17x8" et35 will stick out by 13mm or 0.5" which is fine.
205/40-17 fits rims 7-8" wide, but it is not OEM sized and runs small on tire diameter at 23.5". Used with stock suspension will give a larger wheel gap.
If you roads are smooth and good then the 40 series sidewall will be OK but if you have potholes watch out.
A better choice for tire size is 205/45-17.
Old Jul 31, 2013 | 06:25 AM
trithumb's Avatar
trithumb
Yep
lol this is on my current wheels right now. I am lowered on some sort of springs. I bought the car and the previous owner had lowered it. I have no idea what the spec of the wheel is. I have yet to pull a wheel off to check to see if the offset is stamped on the inside of the wheel.
I am looking at a set of rota torques that are the listed specs so we will see how they look. I am currently cambered in slightly on all wheels I may have to adjust the camber a little more when i get these guys mounted. Does the car have stock adjustable camber plates/arms? I spent about 30 min looking around online trying to find how to adjust them if so with no luck.
Old Jul 31, 2013 | 09:30 AM
Alex@tirerack's Avatar
Alex@tirerack
I have had customers who have required a bit of fender trimming, or additional negative camber added .
Old Aug 1, 2013 | 08:09 AM
trithumb's Avatar
trithumb
Good to know. I am already cambered in. I may have to figure out how to adjust the camber on it a little further. Thanks for the info!
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
