lug pattern and offset for wheels
Old Mar 30, 2004 | 06:30 PM
graniteman74's Avatar
graniteman74
Does anyone know wht the lug nut pattern and wheel offset is for 2004 mcs?
Old Mar 30, 2004 | 06:36 PM
Chief_Charlie's Avatar
Chief_Charlie
The lug pattern is 4 x 100 for a MINI---all MINIs The Offset is 50 for a 17 inch S-Lite . Thae a look at the FAQ at MINI2.com for more information on the offsets for all the MINI wheels
Old Mar 30, 2004 | 06:37 PM
The_Beastmaster's Avatar
The_Beastmaster
Don't forget, hub bore is 56.1mm.
Old Apr 2, 2004 | 01:22 PM
Arly's Avatar
Arly
38mm offset is the widest you can go before your tires start rubbing. I have BBS RGR's and they say that I can not lower my MINI with setup. I can however trim so that I do not get any rubbing.
Carl
Old Apr 2, 2004 | 04:06 PM
MINIAC's Avatar
MINIAC
There are people running wheels with offsets as low as 35mm:
http://www.mini2.com/forum/showthread.php?t=35500
Old Apr 2, 2004 | 09:58 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
If you have the stock suspension the limits of offset are from 37mm to 50mm according to Randy Webb of Webbmotorsports. 35mm is really pushing the limits and might be possible depending on which tire size is selected and how heavy a load you have in your card.
For H-sport springs the offset limit is 42mm. It varies a little for each suspension set up you may have.
SosoMINI
Nov 22, 2015 03:17 PM
madmaxxed
Sep 2, 2015 03:32 PM
TOMSR53
Aug 26, 2015 10:18 AM
StuRat
Aug 24, 2015 06:24 PM
Mini'mon
Aug 16, 2015 04:15 PM
