Rim width?
Old Sep 22, 2012 | 02:27 AM
MNIPWR's Avatar
MNIPWR
Rim width?
What width of rims would i need for 225/45/R17? would 7.5" be good or would I need 8" Also would they fit?
Old Sep 22, 2012 | 06:19 AM
Creeve's Avatar
Creeve
This should help: https://www.northamericanmotoring.co...5-45-17-a.html
Old Sep 22, 2012 | 07:16 AM
cristo's Avatar
cristo
Alliance Member
Standard range of rims for this size tire is 7" to 8.5".
7.5" would be a very good choice.
So would 8".
As for "would they fit?", would need to know what vehicle and what offset and what springs.
Old Sep 23, 2012 | 05:15 AM
GreyLens's Avatar
GreyLens
Getting 225-45-17's to fit is the bigger challenge. Plus the wider the rim the wider the tire will expand. The 8" is much better from a handling perspective since you want as much width on the rim as you can get and stay just under the tire width. Team Dynamics has an 8" rim that several folks have used locally with 235-40-17's with just minor rubbing.
I had rubbing with 225-40-17 A6's for autocross on 7" Kosei K1 TS rims and had to push them out with spacers...5mm rear and 10 to 15mm front. The 225-45 height might be the biggest challenge for you. I run 215-45-17's for DDing on 7" rims.
The referenced thread from Minihune has great info.
Doc Pain
Mar 10, 2021 04:50 AM
luisfv56
Nov 16, 2015 01:55 PM
malibujoey
Nov 9, 2015 08:22 PM
Winston46
Nov 9, 2015 06:18 AM
MINIAC
Site Feedback
Oct 1, 2015 02:30 PM
