Rim Compatibility
Old Jul 5, 2012 | 07:19 PM
italchef's Avatar
italchef
Rim Compatibility
Hello;
I wonder if anyone can tell me if OEM 16" rims with snow tires from a 2003 Cooper S will fit on a 2012 Cooper.
Thank you in advance,
Italchef
Old Jul 5, 2012 | 08:53 PM
bluefox280's Avatar
bluefox280
Have the specific width and offset of the wheel?
- Erik
Old Jul 6, 2012 | 05:29 AM
rum4's Avatar
rum4
Remember to check the diameter of the holes as 1st gen uses 12mm and 2nd gen uses 14mm, so depending on the wheel the holes may need to be bored out!
Old Jul 6, 2012 | 06:54 AM
bluefox280's Avatar
bluefox280
Originally Posted by rum4
...so depending on the wheel the holes may need to be bored out!
FALSE.
Originally Posted by MINI2 FAQ
On July 12, 2006 the size of wheel bolts was changed from M12x1.5 to M14x1.25. There exists a misconception that this change in wheel bolt size precludes fitting early OEM wheels on later model cars. This is simply not true as all OEM wheels have holes large enough for either size wheel bolt.
- Erik
malibujoey
Nov 9, 2015 08:22 PM
Winston46
Nov 9, 2015 06:18 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Oct 1, 2015 08:55 AM
