De-Runflating a OEM wheel
Old Mar 18, 2012 | 11:15 AM
rustyeuro's Avatar
rustyeuro
Is there something special about MINI's OEM runflats that would make them useless without the run flat band?
My thought is, I don't want run flats (but the R83's i picked up are). Can i just have a shop remove the band and run just the tire on rim?
Old Mar 18, 2012 | 12:26 PM
ZippyNH's Avatar
ZippyNH
Mini are rims are 100% standard.
The runflats that mini use do not use a special rim...they are refered to a DSST.
So the rim can be used with a normal tire....and the mini runflats can be used on any rim (with a tire psi montoring system).
Old Mar 18, 2012 | 12:30 PM
ZippyNH's Avatar
ZippyNH
PS
Most any shop can demount the mini runflats....the sidewalls on the tires are very stiff, and the remover must go VERY SLOW, USE LOTS OF LUBE, AND USE PLASTIC COATED SPOONS (MOUNTING/UNMOUNTING TOOLS). Many shops rush...and scratch ip the rims...a shop that advertises does runflats...like a branded goodyear dealer might charge you more, but have the tools to do it...some have a machine.
Old Mar 18, 2012 | 12:55 PM
rustyeuro's Avatar
rustyeuro
perfect! thanks for all of the information. I'll keep the plastic coated tools in mind when i ask the various shops.
thanks!
Old Mar 18, 2012 | 01:56 PM
MCS Fever's Avatar
MCS Fever
Ditched ours for the tires in my sig on stock (but chrome) wheels.
G1HQ
Dec 7, 2015 02:23 PM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
Dashdog
Aug 10, 2015 06:17 AM
