First push of brake pedal spongy
Old Oct 29, 2011 | 02:32 PM
Mini2na's Avatar
Mini2na
I bled the brakes system without incident 700 mi ago. Brakes were fine. The service minder then told me I needed to service the front brakes soon so I changed the pads and rotors in the front and the pads in the back.
During the install, I had to remove fluid from the master cylinder to accomodate fluid from pushing in the wheel cylinders so the new pads would fit. I never opened a bleeder valve or pushed the brake pedal.
I put it all back together, topped up the master cylinder and pumped the brakes. Had to add just a bit more fluid to bring it up to full. (It did not take all the fluid I removed in the beginning.)
During my test drive I noticed the first time I press the brake pedal it goes down more than usual and feels a bit spongy. After the first press, the next presses feel firm if I brake in succession. When I wait 30 seconds or so, the spongy feel is back for the first press.
Any suggestions of what to check or do? I don't want to drive the car until I get this solved. Do I need to bleed the system again even though I did not open it up?
Old Oct 29, 2011 | 07:58 PM
HRM's Avatar
HRM
You need to bed the pads. New brakes are not good until there is some material transfer from pads to rotors.
http://www.essexparts.com/learning-c...ost/Bed-in?v=2
Old Apr 25, 2012 | 02:35 PM
stylin99's Avatar
stylin99
Did you ever figure out your problem? What fixed it? I have the same issue right now.
Old Feb 13, 2020 | 05:51 PM
lcac1779's Avatar
lcac1779
If it is spongy just like someone mentioned, more than likely it need to be bled more or there’s a leak allowing air into the system. If that doesn’t work, then the master cylinder need replacing.
Old Feb 14, 2020 | 04:51 AM
Minibeagle's Avatar
Minibeagle
Could also just need some more bleeding too. Get a power bleeder - worth every penny
stylin99
Jun 11, 2012 08:10 AM
Thomas1
Aug 1, 2011 07:07 PM
guru220
Tires, Wheels, & Brakes
15
Nov 20, 2009 11:09 PM
RedSkunk
33
May 9, 2008 08:03 PM
paulmon
Jun 7, 2004 11:16 AM
