Caliper rebuild-How do I stop the lines from draining?
Old Oct 6, 2011 | 09:47 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
My front calipers on my '05 MCS are starting to sling fluid seeping from the piston seals. Time to re-build. I've got stainless steel lines. Anyone got a good suggestion for stopping up the lines to keep fluid from draining out?
Old Oct 6, 2011 | 12:23 PM
Capt_bj's Avatar
Capt_bj
most common thing to try is a wooden golf tee
I saved an old brake line, cut off the appropriate end fitting, used some epoxy to seal the end and use that as a plug . . .
Old Oct 6, 2011 | 12:30 PM
DneprDave's Avatar
DneprDave
KD tools makes a selection of rubber plugs that you can block the brake line with.
They come on a beaded chain, to keep them together.
Most good auto parts stores have a KD tools display rack
Dave
Old Oct 6, 2011 | 01:51 PM
NC TRACKRAT
Veteran: Navy
Thanks for the K-D tip. Next question: Anyone changed out front dust boots? What's the trick?
squawSkiBum
Sep 2, 2015 09:56 PM
Ntety
Sep 2, 2015 08:39 PM
Llanrhaeadr_Cymru
Country Roads MINIs
Sep 2, 2015 07:12 PM
Sep 2, 2015 09:05 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
