2005 Tires
2005 Tires
Hello everyone! I have a 2005 Mini Cooper S and want to change to regular tires, trouble is the 195/55/16's are hard to find in my area! Are there any other sizes i could use without having to change out the stock rims that came with the car? any help would be great
Hello and welcome to the board. I think a 205/55/16 would be fine, but I'm no tire expert. However you might want to look at www.tirerack.com
Not sure about prices in your area but even after paying shipping, i saved like $300 by ordering from tirerack over buying retail in town. Alex is the man, he can hook you up.
alex @ tirerack . com
+1 on Alex and Tire Rack.
205/50/16 is another popular size replacement for the OE size. It will be slightly smaller in diameter than OE, while the 205/55/16 will be slightly larger in diameter. The former should provide for a sharper turn-in (less sidewall to flex), while the latter should provide a somewhat softer ride, and might also make your speedometer more accurate.
I have the 205/50/r16...added a bit of tourque to the lowend, but did add a tiny bit of rpm/noise is cruise....i'll be trying the other size if i can't find a deal on the oem size...mostly to fillin the arches better and slightly reduce cruise rpms.
but in all honestly, the differance total is about 3-5 mph at highway speeds....less when slowe (various calculors are on the net), or check it with a gps once installed....a quick note, some retailers/club stores are not alternate size freindly......
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
SolCalMini
Aug 29, 2015 07:25 PM
