Autocross Tire/Wheels
Old Mar 20, 2011 | 03:52 AM
  #26
howsoonisnow1985's Avatar
howsoonisnow1985
Sweet!
Cannot wait to try the RS3's in 225/45-15.
Old Mar 20, 2011 | 08:01 AM
  #27
dmyer's Avatar
dmyer
Originally Posted by cmt52663
glad to hear it!
what are you using for warm pressures on those RS3s?
I put 39 LBS in them cold and did not check them again... I am still just concentrating on finding the course and driving it better... traction does not seem to be an issue as much as taking better lines, finding the right breaking points and transitioning the from braking to power on smoothly to load the suspension so I can use the new found traction! But I sure had a blast yesterday. When I saw the final results I see that some of the last runs passed me in times - but I am still right in the scrum of far more experienced autocrossers with similar cars and tires. I was the fastest of 5 Minis including a JCW so I guess I have those bragging rights!
Old Mar 20, 2011 | 08:53 AM
  #28
cmt52663's Avatar
cmt52663
too much fun - congrats on moving up in the shark tank!
y'might try more in the back - I'm running a full STX setup so YMMV but I generally am 38/48 front to back.
better rotation with more pressure has been my experience, but it gets to be a handful in slaloms with too much.
36/36 on the street, which avoids any twitchiness
cheers,
Charlie
Old Mar 20, 2011 | 02:33 PM
  #29
mini coop's Avatar
mini coop
I believe that 15 may be the best. They are typically lighter in weight, first of all, then say a 205/50/15 willl improve the gear ratio for better acceleration. 225/45/15's would be agreat combination.
Old Mar 20, 2011 | 04:10 PM
  #30
cct1's Avatar
cct1
I've tried both 225/45/15 and 205/50/15, and the 225 combination really hits the sweet spot nicely. Not that the 205's are bad, but the width of the 225's wins out...
Old Mar 21, 2011 | 09:27 AM
  #31
cmt52663's Avatar
cmt52663
me too on the 15s, but of course that dog won't hunt in D Stock...
STX however....
Old Mar 21, 2011 | 09:00 PM
  #32
Jim Michaels's Avatar
Jim Michaels
Thanks for the feedback, Dan. I love it when we can help push someone else down the slippery slope.
Old Mar 22, 2011 | 01:22 AM
  #33
truckboy's Avatar
truckboy
If you want to confirm the size on the tires, I think you should consult this with a good tire installer, because he knows, what fits best and what works best.
____________________________________
Motorcycles For Sale | Scooters For Sale
Old Mar 26, 2011 | 09:21 AM
  #34
knighty87's Avatar
knighty87
are you running those tires on the x-lites? and is your car lowered at all? do you think there would be room for a 1" drop with them? im trying to decide if my 05 mcs would fit the 225/50/r16's with 1" drop (h&r springs with bilstein sports).
Old Mar 26, 2011 | 10:14 AM
  #35
dmyer's Avatar
dmyer
Yes - I am running the 225/50/16's on x-lites - I cannot speak for an 05 MCS as mine is a 07 MCS - they are slightly different - but they fit with plenty of room for compression and turning on mine - IMO you could easily lower an 07+ MCS an inch... but that may not apply to your car.
DAn
Old Mar 26, 2011 | 10:17 AM
  #36
knighty87's Avatar
knighty87
thanks, thats what i needed to hear, i figure if worst comes to worst i will have to shave a little off the fender liner or something.
Old Mar 28, 2011 | 12:06 AM
  #37
MotorMouth's Avatar
MotorMouth
Just wait until you move up to r compound tires. The difference is dramatic.
Old Mar 28, 2011 | 03:20 AM
  #38
cmt52663's Avatar
cmt52663
Yep - particularly on a cool/damp day with the first run.
When I was running R comps, the first run was usually good for either a long slide or a spin, as the back end would have no traction to speak of.
But on a warm day, and once the tires had heat - wow!
It's been much debated what the difference is in lateral G, but my own data indicates about 1.2 on stickies, and about 1.1 on treadwear 140 rubber.
Of course the stickies have much stiffer sidewalls, turn in faster, and are a bit less forgiving of slip angle so the overall driving experience changes in more ways than just max grip.
I was banished to ASP for the first few years of running the Works car (due to the "trunk kit" status of the dealer installed option at the time) and I don't regret my trip to the dark side. Too much fun.
Nice not to change tires so often though (lazy me).
Cheers,
Charlie
Old Mar 28, 2011 | 10:19 AM
  #39
MotorMouth's Avatar
MotorMouth
lol, the first run was always kinda spooky!
Old Oct 1, 2011 | 04:55 AM
  #40
Lainford Express's Avatar
Lainford Express
This is interesting, I've got nothing but grief that x-kites on't fit my 2011 R56 and that 225/50R16 will rub. Is there that much difference between the earlier R56 and the current one? Well, besides the annoying I couldn't get a LSD because they dropped the option.
Old Oct 1, 2011 | 11:02 AM
  #41
dmyer's Avatar
dmyer
The X-lites with 225/50R16 should fit very well... the 2011 is identical to the earlier R56... I run that combo on my 2007 with plenty of room to spare.
Old Dec 7, 2011 | 06:51 AM
  #42
honda93's Avatar
honda93
Making the jump from R-Comps back to Extreme Streets. Glad to see the choices were narrowed down. Admittedly, pressing the "Easy Button" for tire choices (regarding the A6) will be missed... Seeing my bank account dwindle by $1000 twice a season won't.
Doc Pain
Mar 10, 2021 04:50 AM
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
minimofo
Sep 20, 2015 05:17 PM
Keet
Sep 20, 2015 01:02 PM
Keet
Sep 19, 2015 09:45 PM
