Konig Retracks?
Old Dec 15, 2010 | 09:31 AM
suilobo's Avatar
suilobo
Konig Retracks?
Anyone know if these Konig Retracks will fit on a 2010 Mini Cooper Mayfair Edition? It came with 17" but I'm looking at the 16" for use in the winter.
http://www.1010tires.com/wheel.asp?w...eelbrand=Konig
Old Dec 15, 2010 | 10:05 AM
amberback's Avatar
amberback
They should. I've come across them a few times when searching for white wheels for my MINI.
Old Dec 15, 2010 | 10:23 AM
Agarwaen's Avatar
Agarwaen
As long as the bolt holes are compatable with 12 and 14mm, they will fit.
I run ET40 17"s, with no prob, so 16s should fit just as well.
Old Dec 15, 2010 | 12:27 PM
mini coop's Avatar
mini coop
12mm and 14mm shouldn't matter as 12mm bolts were for Mini's prior to August of 2006. Five years later Konig should have updated information available. I would be more concerned over the offset and whether it will fit over the brakes. Most sixteen's will, but, there are exceptions. These are also available through Discount Tire Direct.
Old Dec 15, 2010 | 12:45 PM
iwashmycar's Avatar
iwashmycar
Theyll fit fine. All you need are the hubcentric rings, which if they are anything like Tirerack, theyll have them.
Im running 16x7 et40 at the moment for my winters w/ 195/55/16s
The stock rims wouldnt clear my coilovers, and these do just fine
Old Dec 15, 2010 | 12:51 PM
Agarwaen's Avatar
Agarwaen
Ahh, Missed the fact that he said his MINI was a 2010, I was just covering both Gens.
Don't think it would be a problem fitting over the brakes, but if you order from Discount Tire, you can test fit one and if its a no go, return it for the cost within 30 days. If you have not mounted a tire onto the wheel.
Of course, you would be out shipping charges.
schwac2
Jun 14, 2016 04:06 PM
boholio
Nov 9, 2015 03:50 PM
srhodes
Oct 8, 2015 05:17 PM
sandtoast500
Tires, Wheels, & Brakes
Jan 10, 2007 08:17 AM
