Grease wheel centering hubs?
Old Jun 9, 2010 | 08:30 AM
donjulio's Avatar
donjulio
Grease wheel centering hubs, huh? Is that where the hub mates with the wheel?
Old Jun 14, 2010 | 11:09 PM
donjulio's Avatar
donjulio
Its in the service manual, anyone know what this is.
Old Jun 15, 2010 | 01:39 AM
rkw's Avatar
rkw
What's the context of your question? Do you want to apply grease to prevent the wheel from bonding to the hub?
The hub has a center flange that sticks out for centering the wheel. You can apply a very thin layer of grease or anti-seize to the sides of the flange. Do not allow any to get on the flat surface of the hub.
Old Jun 16, 2010 | 11:43 AM
Alex@tirerack's Avatar
Alex@tirerack
as well keep it off any lug hardware!
Old Jun 17, 2010 | 02:27 AM
asp1880's Avatar
asp1880
Interesting. I greased the hubs when I changed from winter to summer wheels this spring. The winter wheels stuck a bit because of corrosion. I might have strayed onto the flat surface with the grease. Why is that bad?
Sincerely,
--Anders.
Old Jun 17, 2010 | 04:28 AM
THE ITCH's Avatar
THE ITCH
Anders
Your wheels are actually held in place by the torque between the two surfaces of the wheel and the hub and not the lug bolts. It is a good idea to clean these two surfaces whenever remounting wheels. As others have mentioned you can use a small amount of grease around the centering ring but not on the hub surface. If you have greased this area be sure to remove it ASAP. Brake cleaner would work well for this job.
Steve
Sincerely,
--Anders.
Old Jun 17, 2010 | 08:04 AM
Alex@tirerack
Not to discount the roll your bolts play, as the facilitate the hub to flange torque. They don't like grease either!
Alex
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
