Mini Tire Question
Old Feb 26, 2010 | 04:40 PM
Big Ben's Avatar
Big Ben
Mini Tire Question
I'm new to the forum so please forgive me if this is an old question. We've had or mini for 2 years and it's time for some new tires. It is a requirement to run the run-flat tires ? or do some choose to run 'regular' tires and carry a spare or fix a flat etc ?
Old Feb 26, 2010 | 04:53 PM
jcauseyfd's Avatar
jcauseyfd
No, you are not required to use run-flats and many people change over to non-run-flat. You should be able to find many threads regarding the possible choices you have.
My guess would be the majority of folks who switch to non-run-flat carry some type of roadside repair kit (slime, compressor, plug kit, something) and probably a bunch have AAA as well.
Old Feb 26, 2010 | 05:33 PM
ZippyNH's Avatar
ZippyNH
in the US anyway, this is how most of us do it...it is taking a bit of a chance, but the cost savings, and ride/handling improvement IMO is well worth the risk. There is also a much wider selection of tires in non runflats, especially if you use an alternate size, such as slight wider, while adjusting the sidewall height to keep diameter the same will yeald more options, cost savings, and a grip increase.
Old Feb 26, 2010 | 05:56 PM
Big Ben's Avatar
Big Ben
Thank you both very much !
Mini'mon
Aug 16, 2015 04:15 PM
Mini'mon
Aug 16, 2015 12:47 PM
Dashdog
Aug 10, 2015 06:17 AM
jrezzo
Aug 9, 2015 10:32 PM
nomar116
Aug 9, 2015 09:42 AM
