Enkei PF01
Old Feb 2, 2014 | 08:34 PM
  #176
simplybao's Avatar
simplybao
Originally Posted by minihune
Yes, but you need to be careful which tire to use if you are lowered. These wheels will stick out 10mm more than OEM wheels
Using stock suspension you can use-
205/45-17
215/45-17
If you have a lowered suspension you may need to run more negative camber to tuck the edge of the tire into the wheel arch area. You can trim the wheel arch plastic. 205/45-17 will give you better clearance unless you want to go smaller in tire diameter than stock such as 215/40-17 or 205/40-17 but tire selection is much less.
I'm thinking about these wheels but I like the 215/45/17 size because of the extra sidewall. What kind of negative camber would I need to run? I have h-sport control arms. Also, I like the conti dws tires.
Chibi2
May 19, 2016 03:46 PM
actualsize37
Nov 18, 2015 08:58 AM
Ladybug-S
Sep 10, 2015 07:08 PM
slitcher
Sep 7, 2015 06:17 AM
actualsize37
Sep 1, 2015 06:43 AM
