"Low Tire" Warning
Old Oct 6, 2009 | 02:41 AM
  #26
larrydk's Avatar
larrydk
I'm too lazy to read all the posts, but everyone realizes that the TPMS has to be reset to your operating pressure. The TPMS monitors loss in pressure. Check out your manual for instructions
Old Oct 8, 2009 | 04:14 PM
  #27
investigator's Avatar
investigator
Originally Posted by Dimples
Hey guys,
I have no experience with cars that monitor the tires or with run flats.
I have a 2009 Cooper S with run flats and this morning when I started it, it told me "Low Tire." I got out and looked, but you can't really see on run flats is what I've heard. I went the gas station and check the pressure. All 4 read about 34/36. My manual says they should be 38/40 so I added some air and reset the monitor per the instructions.
My question is, how do I know the difference between normal pressure loss and something else? I didn't see a nail, but I also didn't know what tire to check. Is there a different warning for a flat tire? or a punctured tire?
Thanks in advance.
Read your owner's manual.
Old Oct 9, 2009 | 09:23 PM
  #28
Dimples's Avatar
Dimples
I did read the owner's manual. That's why I knew how much air to put in and how to reset the sensors. That wasn't my question.
Old Oct 14, 2009 | 04:56 AM
  #29
SnappleLlama's Avatar
SnappleLlama
I'm totally glad I found this thread. This morning, Murphy informed me that I had a "low tire" somewhere. I have runflats, but I went out and looked at all of my tires and couldn't find anything. The weather was a bit colder this morning, and it's not supposed to go above 50 degrees (F). I have a tire pressure gauge, so I think I might take a look at my tires on my morning break. I hope it's just the cold weather and not a flat.
I'm particularly paranoid because I have to drive four hours to Pittsburgh tomorrow.
Old Oct 14, 2009 | 07:31 AM
  #30
SnappleLlama
I checked all four tires with a pressure gauge, and they were all roughly 33 -34 psi. One of them was around 32 psi, though, so I suspect it may have tripped the warning light. I'm so glad it's not a flat!! I'll be putting air into the tires later today and resetting the monitor. Yay, Murphy!!
Old Oct 14, 2009 | 01:11 PM
  #31
jmhouse's Avatar
jmhouse
same thing happened to my car the other day. it's been below average for temps around here lately and i happened to be up early in the morning before the sun could warm everything up. the sensor went off and i checked the pressure. didn't see anything out of the ordinary so i reset the sensor. haven't had a problem since.
Old Oct 14, 2009 | 01:45 PM
  #32
corcoranwtnet's Avatar
corcoranwtnet
Yes, if you inflate to the correct pressures and reset the TPMS system when it's particularly cold out, you should have fewer false readings. The pressures will be high if the weather warms up for a few days, but there's no warning for above-normal pressures, just below-normal.
(You still need to use a tire gauge occasionally, particulary when seasons change.)
Old Oct 15, 2009 | 05:36 AM
  #33
sequence's Avatar
sequence
Originally Posted by Riffster
I got that waring a couple weeks ago as well. I checked em and they were fine. Just figured it was the drop in temp that made the warning go off...
U R right. That sudden change to very cold weather in Denver last weekend caused my "low tire" warning to come on, so I just reset it when it was still cold. Pressures dropped each tire from 33 psi to 26 psi.
And with run flats you will know if a tire is flat, esp at slow speeds starting out.
Old Oct 15, 2009 | 07:26 AM
  #34
Kikimowse's Avatar
Kikimowse
Originally Posted by Robin Casady
Dimples: get a good tire pressure gauge. I like this one, YMMV
Thanks for the link. I have one of those tyre pressure gauges with the crooked shank. Due to the design of my wheels, I end up letting out air everytime I take a read. My father has an old brass one (that has seen better days) much like the one at Moss and it works so much better. I just purchased three, one for me and my MINI, one for my sister and her MINI and a new one for my Dad. "On the first day of Christmas my daughter gave to me......a Moss MINI tyre pressure gauge!" Hey I have begun my Christmas shopping early this year. Thanks
Old Oct 16, 2009 | 12:22 PM
  #35
slindo's Avatar
slindo
This seems unlikely, since the manual for our 2009 Cooper says it doesn't sense pressure, but circumference, and there are no signs of a pressure-sensing system.
In Sept 2007, the US Government required all new cars to come with in-wheel sensors that measure air pressure..
Old Oct 16, 2009 | 12:30 PM
  #36
cmcveay's Avatar
cmcveay
I'll have to read that section of the manual but that doesn't seem like it could be entirely true. If that were the case, did the car remember from yesterday that it didn't count properly and it's telling me the next morning? The last two times I've had that warning was when I went out in the morning and started the car and I hadn't moved yet. No rotations = No reading which should = No warning? I'll be at a dealership for a meet and greet on Saturday, I'll see if there is anyone in the service department to answer the question...
Old Oct 16, 2009 | 01:17 PM
  #37
pilotart's Avatar
pilotart
My 2008 Owners Manual described both tire pressure warning systems.
If you have rubber tire valve stems, it is the circumfrence system and if they are metal, it is the electronic transmitters system.
Old Oct 16, 2009 | 02:11 PM
  #38
Robin Casady's Avatar
Robin Casady
It's the law (NHTSA 2005-20586) look it up. If your Cooper was purchased in the USA, you should have TPMS sensors in your wheels. Do you have rubber or metal valve stems?
Old Dec 1, 2009 | 04:50 PM
  #39
DMT's Avatar
DMT
Same thing here this morning. Temp was colder than it had been and upon start up, TPMS warning went off. Checked and the rears were 31, the fronts were 33. Threw a few pounds in all to get them at 34, did the reset and all is fine. Seems the system is on the sensitive side.
Old Dec 2, 2009 | 06:50 AM
  #40
sequence's Avatar
sequence
My April 2007 MCS has the rotation based FTM (Flat Tire Monitor).
All MINIs had this until the August 2007 builds. My 05's FTM was very sensitive. Rubber stems = FTM. Metal stems = TPMS
I also tend to carry a few more pounds of pressure in my rear tires to help with handling and check understeer. I go 32-34 front, and 36-38 rear.
Old Dec 2, 2009 | 11:18 AM
  #41
AkFarina's Avatar
AkFarina
btw if you the last time you filled them it was the summer and 90 outside, and now its 30 it will come on my did the other day.
Old Sep 26, 2011 | 02:47 PM
  #42
Jackelino's Avatar
Jackelino
Hey guys, by the way, don´t you know how to reset the low tire indicator? It happens that my car has no reset button... :( I understand there is a way to do it using a different procedure.
debitsandcredits
Sep 21, 2015 08:34 AM
PSU 98
Sep 11, 2015 11:20 AM
kjd186
Sep 9, 2015 10:02 AM
renchjeep
Sep 6, 2015 01:54 PM
