Konig MP3 - do they fit?
Old Sep 15, 2009 | 07:27 PM
KnightmareCS's Avatar
KnightmareCS
17x7.5
+42 offset
4x100 and 4x114.3
with 215/45/17 tires
What do you guys think?
I have an 04 Mini Cooper with those tires on it, but the rims need to be replaced.
Old Sep 19, 2009 | 11:43 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Do you have stock or lowered suspension?
IF stock suspension then it will fit but it's a little taller and wider than stock but still ok.
Which tires? Kumho Ecsta what? How worn?
If you are lowered then in the rear there will be less clearance.
Old Sep 19, 2009 | 10:29 PM
KnightmareCS
Completely stock.
I'm asking as I do not know what offset would effect the car.
The 215/45/17 are on my car right now on aftermarket ZEN rims. The rims came with the car, the tires I put on. Kumho Ecsta ASX, newish tread.
They rub a little right now at times, but overall they're good handlers. I need to swap rims cause the ones on it are unbalanced.
And also a side question, can I reuse the TPMS from my aftermarket ZEN rims? The valves are rubber if that matters. I don't have a light on, but I know it works.
Old Sep 20, 2009 | 11:08 AM
minihune's Avatar
minihune
Originally Posted by KnightmareCS
Completely stock.
These rims should fit OK with stock suspension.
TPMS can be moved from one wheel set to another. Be careful not to damage them when moving. Try to keep each wheel oriented the same, right front TPMS goes on right front new wheel unless you have already done a tire rotation and TPMS worked fine with wheels in different locations.
Old Sep 21, 2009 | 10:05 AM
KnightmareCS
sweet, great to know. now to make sure if my mom wants those rims. i'll keep the positions in mind.
thanks a lot for your help!
surfblue
Oct 24, 2018 01:20 AM
srhodes
Oct 8, 2015 05:17 PM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
