R90 12 point torq size?
They're not actually Torx bolts, so you'll need to ask for a 12-point bit or a "triple square" bit. The size is 8 mm. The bolts can be hard to remove, since there's blue loctite applied to the bolts by the manufacturer. When you put the wheels back together, use loctite as well, and use 28 lbf-ft for the torque setting.
Make sure the coaters don't over do the powder. Build up is going to happen, but too much and the centers won't go back together. I had a heck of a time fitting my R98's back together. DO NOT use the bolts to "suck" the centers down, can strip threads or snap a head off. Personal experience on both.
Otherwise no problem!
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
atlantaorange
Sep 16, 2015 12:43 PM
