Thunking noise after changing wheels
Old Jan 28, 2009 | 11:37 AM
bimmerbud's Avatar
bimmerbud
I just put new snow tires and wheels on my 05 MCS cabrio this weekend and immediately when I drove it, as I let out the clutch there was a clunk in the right front wheel area like sucking your tongue off the roof of your mouth. It happens on every shift unless I am really soft letting the clutch out. It doesn't change in pitch or sound different as I shift the gears. There's nothing loose, I've taken the the wheel off and re torqued the bolts.
I'm clueless. Why would jacking up the car at the jack points cause something to go bump in the day?
Old Jan 30, 2009 | 09:21 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Since your're not getting any responses Ill throw this out there.
Once, when changing over to my race wheels, one of the
hub centric rings stuck on the hub and I didn't notice. So when I bolted up the other wheel it had 2 rings on it! Figured it out before I drove on it, but that could be a problem to check for.
Old Jan 30, 2009 | 10:44 AM
bimmerbud's Avatar
bimmerbud
Found the problem last night. It's the hydraulic passenger side motor mount. This is the 2nd one in 3 months. The top bolt was loose but know it clunks back and forth.
Bud
Old Jan 30, 2009 | 02:58 PM
th3118's Avatar
th3118
Glad you found it!
Getrieben
Sep 12, 2024 07:03 AM
eliseo1981
Jan 28, 2021 02:45 PM
maestro39
Oct 27, 2015 02:38 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
