RFT v. 55 series performance tire.
Old Nov 15, 2008 | 07:44 AM
Ian Venieri's Avatar
Ian Venieri
Has anybody replaced the stock OE RFT tires with a same size (195/55R16) performance tire and can report on the sidewall differences between the two? I expect better ride but does it steer and corner with less flex?
Old Nov 15, 2008 | 02:01 PM
MINIAC's Avatar
MINIAC
You won't find much of a selection in 195/55-16 non-runflat tires.
Most people plus-size to 205/50-16.
Old Nov 15, 2008 | 04:36 PM
resmini's Avatar
resmini
I changed from runflats to non-runflats and my MINI now steers and corners with more flex.
It does ride smoother though, and, to be honest I don't have the same size tires now. I went from 195/R55/16's on 5-stars to 15" Konig Rewinds with 195/60R/15's.
I doubt you will get "less flex" from non-runflats.
Old Nov 15, 2008 | 06:13 PM
Ian Venieri
Resmini you went to a higher cross section -60- and those sidewalls will flex more.
What type of tires are you using?
Old Nov 15, 2008 | 06:45 PM
resmini's Avatar
resmini
Yep, but even factoring that in I'd still say the runflats will flex less because the sidewalls are so stiff.
I got Falken 912's, mainly cause I couldn't resist the low, ($51), each price, and Consumer Reports rated them highly.
Actually they are just fine, and I don't know if this has anything to do with their quality or not, but the four new Konig Rewind wheels and Falken tires only required 1/4 oz. of weight to balance......three of them required no weights, and one required 1/4 oz. I never had that happen with a set of tires before.
Old Nov 20, 2008 | 07:14 PM
wscruiser's Avatar
wscruiser
Found this quote on another thread, maybe it will help answer you question.
"Careful now.
Different brand and model tires have vastly different side wall stiffness. Any tire model and size needs to be evaluated on a car like yours with the same suspension set up.
In case you decide to take a third party's advice be sure that they are experienced drivers and have driven that exact tire size on a car like yours."
Gabe3
Tires, Wheels, & Brakes
16
Apr 16, 2016 07:55 AM
wheresaldo
Oct 23, 2015 10:17 AM
hexproject
Sep 7, 2015 08:23 PM
Zettinger
Aug 25, 2015 04:04 PM
Aug 25, 2015 07:11 AM
