R56 Lug Nut ?'s
Old Nov 2, 2008 | 04:56 PM
elpappy's Avatar
elpappy
R56 Lug Nut ?'s
Thanks in advance for helping me out with this!
I'm looking at some new wheels 16' Black Superturismo GT's (when they become available from Tire Rack). I would like to get red lug nuts to go with them (Gorilla Automotive). What size do I need and does anyone have pictures of black wheels and red lugs?
Links of interest:
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
http://store.summitracing.com/egnsea...=KeywordSearch
Old Nov 2, 2008 | 05:04 PM
ScottRiqui's Avatar
ScottRiqui
Unless you've installed a stud conversion on your car, it doesn't use lug nuts - it uses lug bolts. If you want to use nuts, you'll need to install studs on your car.
You can get 14mm x 1.25mm studs (which is the size your car takes), but I don't think you'll be able to find red nuts in that size. 14mm X 1.25mm is a *really* weird size, and I think MINI is the only company that uses it for their lug bolts.
Your best bet would be to go to Texas Speedwerks (www.txwerks.com) and get a set of conversion lugs from them. You need the ones that are 14mm x 1.25mm where they screw into the hub, and then neck down to 12mm x 1.5mm. If you look at the gorilla nuts page in your post, almost all of those nuts are available in 12mm x 1.5mm size.
Old Nov 2, 2008 | 05:15 PM
elpappy's Avatar
elpappy
ScottiRiqui: Thanks for the great info and quick response! I'm going to check out the stud conversion.
I still would like to see if anyone has pictures of red bolts on black wheels.
rtk90
Aug 29, 2019 09:08 AM
