7.5x15 6ULs?
Old Apr 20, 2008 | 10:27 PM
84im's Avatar
84im
7.5x15 6ULs?
Anyone running 7.5x15 6ULs on their MINI? I'm thinking of purchasing these wheels to go with the Hankook R-S2s (225/45-15) I bought during the last big Discount Tire sale.
I know the 8" wide 6ULs may need a spacer in the rear, but Emilo (produces the 6UL wheel) thinks the 7.5/225/45 combo should clear everything.
My MCS is stock-no mods.
Ron
Old Apr 30, 2008 | 09:11 PM
S-Driver's Avatar
S-Driver
Yes....I run them for a dedicated autox set-up (225/45 Hoosier A6's). I use a 5mm spacer up front to clear my BC coilovers otherwise I think they would clear the stock strut without a spacer (because the stocker has that flat side to the strut). But I couldn't tell you for sure now...
I also think the 8" would clear as well since the rim isn't what's close to the coilover strut, the tire is what's close.
And I do use the 5mm spacer in the rear but it's not needed....
Old May 1, 2008 | 04:47 PM
84im's Avatar
84im
Thanks S-Driver-I put two of my 6UL 15x8 (40 mm offset-off of my monster Miata) on my MCS just to see how they would look. Besides the fact that the rear wheel rubs (inside), the 225/45s look seriously dumb on a standard height MINI (huge wheel gap).
I ended up purchasing a set of 16x7.5 Koesi T1 Racing wheels.
Ron
Old May 1, 2008 | 05:46 PM
S-Driver's Avatar
S-Driver
Look great autox'ing!
Old May 1, 2008 | 11:10 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Ron
15x7 wheels can use 225/45-15 and will fit.
15x7.5 with 225/45-15 is fine.
I use 15x8 +36 offset with 205/50-15, 225/45-15 and 225/50-15 that for the fronts they all will fit with no need for spacers with a lowered suspension.
In the rear the 15x7 rim is fine but the 15x8 rim needs a 3mm spacer to clear the rear lower trailing arm that hits the inner edge of the rim.
Fronts 225/50-15 Kumho V710 on 15x8 rims +36 offset no spacer
Rears 205/50-15 Kumho V710 on 15x8 rims +36 offset with 3 mm spacer
Old May 2, 2008 | 06:53 AM
mbcoops's Avatar
mbcoops
More pics of these wheels - they're awesome!
mb
Old May 2, 2008 | 07:05 AM
theWING's Avatar
theWING
mb
+1 These look so sweet. Especially on the track!
Old May 2, 2008 | 06:05 PM
84im's Avatar
84im
Okay, here's a photo of my monster's 15x8 6ULs (225/45-15 Hankooks) on my MCS. I put them on one side to see what they would look like. I really like the look of the wheel, but the wheel gap is comical. Note that the suspension would probably settle a bit more on its own, and with a lowered suspension this combo would look awesome (in my view).
Ron
p.s. NO laughing at my wheel gap
Old May 2, 2008 | 10:28 PM
minihune's Avatar
minihune
These are with Bilstein PSS9 Coilovers and 1.7" drop front and rears
15x8 6UL rims with 225/45-15 Hoosier A6 tires front and rear(3mm spacer).
Old Dec 17, 2008 | 08:31 PM
kapps's Avatar
kapps
Going to bring this thread back... I haven't heard any issues with low offset wheels but how do you guys think the wheel bearings would do with a +34 offset? I like the 6UL's but the 15x8's seem to be hit or miss in terms of requiring spacers (which I'd like to avoid). The 15x7.5's are great but I wish the offset was a little higher.
Old Apr 5, 2009 | 11:20 AM
04indimcs's Avatar
04indimcs
And I'll bring this thread back again. Any news on these wheels? Especially the 15x8 +36 offset. I really really like them.
Old Apr 5, 2009 | 11:33 AM
minihune's Avatar
minihune
See
http://www.949racing.com/index.asp?P...ATS&Category=2
http://www.949racing.com/index.asp?P...TS&Category=33
Taking preorders with May arrival. 15x8 with +36 offset
$159 each
Silver, Black, Bronze or Nickel finish
Old Apr 5, 2009 | 11:57 AM
04indimcs's Avatar
04indimcs
I love those wheels. Very unique for a 15" rim. Will these wheels be around for a while? I'm looking to buy these down the road at some point.
Old Apr 5, 2009 | 06:45 PM
minihune's Avatar
minihune
Version 1 is selling out now.
The new version 2 is selling now beginning in May so it will be around but do check with 949racing.
Miatas often use these rims. I think Miatas will be around for some time.
Old Apr 6, 2009 | 06:03 AM
04indimcs's Avatar
04indimcs
It seems like these are mainly track/auto-x wheels. How are these wheels for street only use? From my understanding, running a 225/50/15 tire would require some trimming of the plastic fender in the rear. Is this something a body shop could easily do for me?
Old Apr 6, 2009 | 05:10 PM
S-Driver's Avatar
S-Driver
You mean trimming the wheel arch molding right? If so you can easily do that with a dremmel, I would think.
Or do what I did and run the tires and let them do the trimming for you! Tires were no worse for the wear....
Old Apr 6, 2009 | 06:40 PM
04indimcs's Avatar
04indimcs
Are you saying these rub the actual molding or only the inside of the molding? If they only rub on the inside I would most likely let them do the trimming.
Old Apr 7, 2009 | 06:25 PM
S-Driver's Avatar
S-Driver
I run 225/45/15's with a 5mm spacer on a '03 MCS. 15 x 7.5 rims....
They rubbed the inside of the moldings...can't see anything from the outside.
And they didn't rub at any autox's......just when I tracked the car at Watkins Glen.
MiniMio
Tires, Wheels, & Brakes
Dec 24, 2017 10:30 AM
ottawa
May 3, 2015 05:09 PM
Dino S
Aug 8, 2014 09:58 AM
