Tires
Old Jan 29, 2008 | 05:14 PM
mickeys mini's Avatar
mickeys mini
Tires
Am I the only one having excess tier whare?
I hade to replace my rear tires at 15000 due to wereing on the inside.
Hade the alinment dune at BMW at that time.
Now at 28000 agen the rear is out and the front rt side is shot .
Is any one els having this tipe of tire were or laiment trubles ?:impatient
Old Jan 29, 2008 | 07:58 PM
Dan00Hawk's Avatar
Dan00Hawk
Originally Posted by mickeys mini
tier whare
hade wereing
Hade alinment dune
agen
els tipe were laiment trubles
Are you sure the dealer that did the alinment/laiment/alignment understood what you wanted them to do?
All kidding aside, get another alignment done and get the printout to confirm that everything is to proper specifications and that nothing in your suspension is damaged. Also, be sure to rotate your tires in the 5,000 - 7,000 mile range so they wear more evenly, along with proper tire pressure. Hope this helps!
Old Jan 29, 2008 | 08:06 PM
ronmichael's Avatar
ronmichael
What tires and wheels do you have? Performance tires wear quickly. 15k actually sounds reasonable. That's what I've gotten from most of my cars over the last few years. I had an Eclipse GS-T that would wear through tires in 10k!
But if you are seeing uneven wear, you probably need an alignment.
Old Jan 30, 2008 | 07:23 PM
mickeys mini
I hade the dunlaps 9000 .
This time I went with brigstone rft about 50$ less ea .
Used the savings on a life time aliment and rotation.
Thy will be seeing me a lot.
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Ntety
Sep 2, 2015 08:39 PM
