Alex, best track only tire for stock S-lites?
Alex is this true?
What about the Bridgestone Potenza Pole Position S-03
and the Goodyear Eagle F1 GS-D3 for the stock 17" rims. Likely 215/45-17 size.
I think you meant to write Yoko Parada Spec 2 not "yoko parada spec for 205/45"?
Noisy? Fast tread wear? Sticky tires though. I think not as good if wet??
Lets see what the "boss" says...
well this is the best big baller good tire out there.
i looked into cost as well, thus i ruled this out :smile:
yes i meant spec 2. had them on my other car, they were great, very sticky
i live in cali and only drive when sunny, so i care and need 0 wet traction
Oh, Cost is a factor? Eh. Well then you are totally correct. The S-03 are about $163 each.
It is a good track tire if you don't mind the $$$.
Well I live in Hawaii and it rains where I live everyday. But it clears up and the track is in a drier area.
Still it is a consideration. And you forgot to say that you have a big aftermarket audio system so noisy tires
are not a problem. Not even a consideration.
And now for a word from out sponsor (from tirerack)
I would say either s-03 or GS D3. I know of someone running 225/45/17 BFG's KD's.. 17's lack good dedicated track rubber.
Alex
_________________
Alex ext 294
800 522 8473
Tire & Wheel forum moderator
www.tirerack.com
alex@tirerack.com
Alex
_________________
Alex ext 294
800 522 8473
www.tirerack.com
alex@tirerack.com
Kimolaoha
12-05-2020 09:32 PM
