wilwood brake bleed
wilwood brake bleed
Yesterday I tried to bleed my Wilwood Dyna Pro brake, when I bleed I loose the top two bleed nipple but the brake padel is very hard, I tried to loose all 4 nipple the padel feel is still very hard. Anyone have idea what's going on? Thanks for the help.
if you just installed them, i'd check the brake lines to make sure they aren't twisted or kinked. of not kinked or twisted i'd remove the brake line from one caliper at a time to see if any brake fluid drips out. if no fluid drips out then somehow you got a restriction in the line. if fluid is dripping out then theres something going on with the caliper itself, but it sound like your not getting anything to the caliper.
i dont know much about the wilwood setup but i can't imagin its to much different from any other system.
sempaipaul
Sep 18, 2015 03:05 PM
Interior/Exterior Unboxing Video of Sneed4Speed R53 Brake Cooling Kit
Gremothra
Sep 9, 2015 08:42 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
