2006 Mini Cooper S Checkmate Edition with Premium, Chrono Packages, 6-spd & LSD
For Sale2006 Mini R53: "Mk I" Mini Cooper S
Price
$6,000• OBO
- Location Cambridge, MA, 02139, USA
- Condition Used
- VIN WMWRE335X6TL17581
- Mileage 156,668
- Engine 4 cyl
- Drive Type 2WD
- Transmission Manual
- Vehicle Type Hatchback
- Exterior Color Blue
2006 Mini Cooper S, highly optioned, nicely modified and factory super charged. It has lots of miles, but still pulls really strong and is really fun. It’s loud, fast and handles like a go kart.
Premium Package
- Pano Glass Sunroof
- Heated Seats
- Center mounted oil temp. oil pressure, coolant temp gauges
- Speedo and Tach are mounted over steering wheel
- 6-speed Manual
- Limited Slip Diff
- HarmonKardon premium audio
VIN: WMWRE335X6TL17581
Mileage: 156668
Color: Blue
Transmission: Manual
Modifications:
Alta Intake
Alta 15% Underdrive pulley
Alta 2.5” Stainless cat-back exhaust - Sounds like this:
Includes:
Set of 4 Blizzack LM60RF 16” snow tires mounted to spare Mini wheels. I can put these on for you if you wish.
Set of Zipee Sun/Moon roof shades.
Service History, Most Recent first, all receipts included in sale.
9/2022
Good News Garage, Cambridge MA
New rear brake lines
$650
8/2022
German Performance Svc Brighton, MA
New Engine mounts
New right wheel hub and speed sensor
Sunroof drains cleaned
New Power Steering hoses
New serpentine belt
New cabin filter
New steering rack boot, right side
Compression test
$2200
12/2020
New left steering knuckle (I messed it up doing the ball joints)
New left ball joint
New rear struts and springs (BMW OEM)
$1600
11/2020
Owner
New Power Steering cooling fan
Ball joints
$160
9/2020
Owner
All 4 Wheel Bearings
Both Front Axels
$325
2/2020
Owner
All Brakes, pads, rotors and sensors
$328
11/2019
Owner
Timing chain tensioner
$50
4/2019
Magazine Shell
4 New Tires - Sumitomo HTR A/S PS02 205/45R17
$258
4/2019
eBay
New Rim (someone had welded a crack on one.)
$170
3/2019
Owner
OIl & Filter Change
E-Brake cables
New Lug Bolts
New Spark Plugs
$230
Bought 11/2018
151K mi
Previous Owner:
10/2018
Central Motor Sales
New Thermostat
New Coolant Temp Sensor
New O2 Sensor
$650
9/2018
Foxfield Auto
New Spark Plugs
$137
4/2018
OIl & FIlter Change
Rotated Tires
$97
11/2017
Alignment
$214
6/2017
JiffyLube
Oil Change
Coolant Flush
$210
11/2016
Winter Tires Blizzack LM60 RF 195/55R16
$500
The Issues:
CEL - Car has an intermittent CEL for 3rd cylinder misfire
Compression and Leakdown performed in 8/2022 showed all cylinders between 110-130. Healthy Mini engines should be in 150-160. This car will likely need a top end/valve job in the future, depending on how you treat it. Check the oil regularly (every 3rd gas fill) and you will get more life out of it. If not, it might eat a valve and leave you stranded.
Control arm bushings are noisy, I would put R56 aluminum control arms on with new urethane bushings.
The oil change intervals are 15k on this car, I do it at 8k and check it regularly.
I have only put 5k on it in 4 years.
Why I’m selling:
I no longer need the car, it was a car that I drove to work (6mi/day), could park in the city easily and something I could lend to friends if they needed to borrow a car. I work from home now.
Cash only. Clean Title in hand.
$6000 obo
Space Blue/Silver was a one year only (2006) color. Checkmates could be had in that color, Hyper Blue(sort of royal blue)/Silver, or Pepper White/Black. The bonnet swoop stripes are correct, but the scoop should be silver. Also, on the exterior, there were “Checkmate” decals on the B pillars. The wheels would be Flame Spokes from the factory. In the interior, a true Checkmate would have a body color dash and the seats would be Space Blue leather bolsters and headrests with silver colored cloth inserts. The steering wheel would be two tone Space Blue/Silver leather.
