2011 Mini Cooper S (Turbo, N-18) - No Mechanical Issues
2011 Mini R56: "Mk II" Mini Hatch/Hardtop range
  • 2011 Mini R56: "Mk II" Mini Hatch/Hardtop range - 2011 Mini Cooper S (Turbo, N-18) - No Mechanical Issues - Used - VIN WMWSV3C5XBTY20670 - 119,000 Miles - 4 cyl - 2WD - Manual - Red - Elk Grove, CA 95624, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $7,800
  • Location Elk Grove, CA, 95624, USA
  • VIN WMWSV3C5XBTY20670
  • Mileage 119,000
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Exterior Color Red
DESCRIPTION/FEATURES:
Performance is great and pulls strong. Awesome handling and great braking as expected. Drives very smooth and is ready to be enjoyed for many years to come. This car has the newer gen N-18 engine (turbo). The car does not have any mechanical/other issues.
-Clean title
-2nd owner
-Smog passed
-6 speed manual
-1.6 Liter Turbo 4-cylinder
-119K miles
-Mpg rating: 29 city / 37 highway
-No leaks
-Interior is in very good condition (no rips or tears)
-Exterior is in good condition
-A/C & heat both work good
-Original Mini roof rack included
-Convenience Package added from factory
-Sport Suspension upgrade from factory
-Anti theft alarm system add on from factory
-Harmon Kardon Speaker upgrade from factory
-Bluetooth built in for phone calls
-Aux line & USB port
-(see photos for full list of features)
WORK DONE OVER LAST 3 YEARS OF OWNERSHIP:
-Walnut blasting intake valves
-Upgraded valve seals
-Crankshaft seal
-Water pump & pulley
-Friction wheel
-Thermostat housing
-Turbo feed and return lines
-Rear brakes
-New tires
-Ignition coils & spark plugs
-Timing chain guides
-Valve cover gasket
-Fan belt and tensioner
-Both VANOS solenoids
-Clutch slave cylinder
-Helix short shifter (only modification ever done, everything else is fully stock)
-Clutch is in good shape
-Timing chain was examined and in good shape
(All parts are genuine Mini or OEM.)
Most of the work done was preventative, only some work was actually needed. I have owned 3 Minis total so I know how to treat these cars right. The car has always been very reliable, never broken down, and never given me any problems since I've owned it. You won't have to deal with any major repair bills since I took care of everything already. I am selling it because I bought an SUV and have too many cars.
(The car has some scratches and some paint chips as expected for its age. Mini touchup paint included to address this. A couple of minor rock chips on the windshield that do not obstruct your view).
Please message me on here if you have questions or want to exchange numbers to talk about the car.
(No Low Ballers please)
