ALTA Hard Turbo Inlet Pipe (Mini Cooper S)
Engine - Intake/Fuel
  • Engine - Intake/Fuel - ALTA Hard Turbo Inlet Pipe (Mini Cooper S) - New - 2007 to 2010 Mini R56: "Mk II" Mini Hatch/Hardtop range - Elkridge, MD 21075, United States
    $210
  • Location Elkridge, MD, 21075, USA
  • Condition New
  • Compatibility
Make Model Year
Mini R56: "Mk II" Mini Hatch/Hardtop range 2007 - 2010
Brand new, never installed or opened. Found out not compatible with N18. 210 shipped USA. Only opened box to take picture.
As the OEM turbo inlet hoses rubber on your MINI Cooper S and the plastic on your MINI Cooper S JCW ages, the material becomes harder and begins to fail. Vibrations and normal maintenance (like replacing air filters) leads to premature failures where the hose meets the turbo. When these failures happen, Check Engine Lights will occur as well as a huge loss in performance. These problems will NOT happen with the ALTA Turbo Inlet hose as it is made of aluminum and seals with O-rings to ensure a lifetime of leak-free performance. CONSTRUCTION - ALUMINUM COUPLER The mouth of the ALTA Turbo Inlet Tube features a CNC'd aluminum coupler. With its precision machined openings, and dual o-ring grooves makes the ultimate seal, with no leaks to mess with your idle or rob you of power. The back edge of the coupler features a traditional style air horn, like those found on race cars, which provides smooth air transition to the turbo inlet. This level of quality and attention to detail is simply not found elsewhere. CONSTRUCTION - ALUMINUM PIPE The ultra smooth interior of the ALTA Turbo Inlet Tube is formed from mandrel bent aluminum tubing. Smoothly transitioning from the filter to the throttle body. Eliminates turbulence and intake restrictions. SIZE ADVANTAGE A side-by-side comparison of the ALTA and OEM turbo inlets clearly illustrates how the ALTA inlet has the largest possible inside diameter. Which simply means more horsepower and better turbo response! Starting immediately after the turbo our 2.62" diameter inlet has a smooth 2.37" diameter bend and then cleanly transitions to 1.82" at the throttle body. FINISH Powdercoated for protection against the elements, the textured finish will look awesome for years to come.
Old Feb 2, 2021 | 03:57 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
In my research, you "should" be able to get it to work with the N18 engine. However, you have to get creative with the PCV tubes.
You can trick the PCV heaters with these:
https://www.ecstuning.com/b-nm-engin...nm.658800~nme/
And the secondary vent tube goes around the back of the block, into a fitting that can be removed and plugged with this:
https://www.ecstuning.com/b-elring-p...137585928~elr/
Old Feb 3, 2021 | 07:00 AM
cityazndan's Avatar
cityazndan
Ah I get that but I rather have a plug and play solution such as M7 for ease of mind.
Old Feb 3, 2021 | 07:05 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I agree 100%, which is why I have an M7 tube on my car
Old Feb 9, 2021 | 09:35 PM
cityazndan's Avatar
cityazndan
Nice, yeah I’ll have to do some more searching.
bump
