Test Forum Use this forum to test signatures, BBCode, etc.
test
Old Dec 30, 2004 | 07:38 PM
chollo9's Avatar
chollo9
test
After I was finished installing my pulley, I looked at my remote battery terminal that had been flopping around in the breeze ever since I had done my HAI and decided that it was time to do something about it. I had been thinking about making a bracket to mount it to the ___ , but since I had already cut up the bottom half of my stock airbox, I figured why not use as much ready-made technology as possible a hack up the top half too!
So if you’re not fond of doing things that keep you from returning to stock, turn away now, because this involves demolition!
The first step was figuring out what was possible—where the terminal box could be mounted, how the cables could be twisted/rerouted, and what would work well and look good without cutting into the drinking portion of the day (which of course starts earlier during the holidays).
[font=Times New Roman][size=3] [/size][/font]
[font=Times New Roman][size=3]After futzing around and throwing out the ridiculously complicated and overly simple ideas, I decided to do the following DISCONNECT THE BATTERY FIRST :[/size][/font]
  • [font=Times New Roman][size=3]Turn the terminal box 90o anticlockwise (this requires disconnecting and minor twisting/manipulation of the two cables—I think they’re called the gazinta and gazouta, but not having my manual nearby I’m not sure). Cut the two wire ties that tie the black (gazouta) cable to its neighbor.[/size][/font]
[size=3][font=Times New Roman] [/font][/size]
  • [font=Times New Roman][size=3]Removal of the two screws that hold the ____ to the ___ at the rear of the engine compartment, driver’s side (non-UK).[/size][/font]
[font='Times New Roman']Chop the original terminal mounting bracket out of the airbox lid along with plenty of extra material (see #4 below for how much you’ll need to end up with, the picture below shows a lot more cut out to the left than what is needed—I was [/font]
Doc Pain
Mar 10, 2021 04:50 AM
jennster
Sep 28, 2015 06:19 PM
silence2-38554
Sep 28, 2015 12:19 PM
Sep 25, 2015 11:46 AM
Sep 25, 2015 11:44 AM
