Suspension Is a 19mm rear sway on med = to 22mm on soft?
Old Apr 2, 2007 | 08:07 PM
MarioKart's Avatar
MarioKart
Vendor
My buddy Jasun just put a 22mm rear sway bar on soft and loves it. I was wondering if I would get the same affects with a 19mm on med. Any info is appreciated.
Thank you
M
Old Apr 2, 2007 | 08:20 PM
jasonsmf's Avatar
jasonsmf
Nope.....according to Alta, the 19mm at full stiff is still softer than the 22mm at full soft
http://www.altaminiperformance.com/p...-Bar-Rear-19MM
(click on charts for the numbers)
Not saying that the 19mm isn't a good improvement over stock....but it's still softer than the 22mm no matter how you slice it.
I assume the other manufacturers 19mm vs. 22mm are similar.
Jason
Old Apr 2, 2007 | 09:06 PM
erickvonzipper's Avatar
erickvonzipper
A friend of mine says that the 19 at full stiff can cause the rear to come around. The 19 at the middle setting is pretty much neutral. I don't know for myself, but I'm getting a 19.
Zip
Old Apr 2, 2007 | 11:00 PM
1nf3rn0's Avatar
1nf3rn0
Heh. And to think i have a 22mm on full stiff and it feels like theres not enough oversteer....
Old Apr 3, 2007 | 09:17 AM
txwerks's Avatar
txwerks
If you have your spring rates right, a 19mm bar is all you need... Less bar = better grip.
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
OZMDD
Aug 17, 2015 02:53 PM
OutMotoring
Aug 6, 2015 09:32 AM
