Suspension ALTA endlinks help
Old Mar 4, 2007 | 04:22 PM
irlracefan's Avatar
irlracefan
ALTA endlinks help
I got the ALTA rear endlinks. I have the ALTA 22mm swaybar. The car is lowered on M7 springs. I know they need to be shorter than the stock endlinks. How do I know where the correct setting is at?
Old Mar 4, 2007 | 04:32 PM
COR BLMY's Avatar
COR BLMY
For an "Anti Roll Bar" to work its best the "arm" should be as horizontal as possable... With the weight of the vehice ON THE GROUND.
Just set them close (maybe a bit shorter) than stock then put the wheels back on and look through the spokes to see the part of the bar that should be flat / horizontal.
Being flat gives the bar its true actual mechanical advantage.
it is a bit hit and miss
When I have my car aligned they will adjust to flat. As they can reach the end link, and the wheels are on the hoist (weight on wheels)
Old Dec 6, 2007 | 08:12 PM
magic mini's Avatar
magic mini
I had the same question and I'm glad I found the answer. Thanks
Old Dec 6, 2007 | 10:47 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Would this also work?
Jack up the rear end of the MINI.
Place two jackstands under the back end to hold up both wheels.
Remove the wheels and remove the stock endlinks.
Won't the rear swaybar hang horizontally? No load.
Then put in the adjustable endlinks to keep the bar horizontal. It's possible the lengths of the two endlinks will not be identical.
Old Dec 7, 2007 | 06:01 AM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
You want to adjust the links with the drivers weight in the car. That way the swaybars have no preload. So it needs t be on the ground, or rack and level.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Dec 13, 2007 | 07:55 AM
Beecher's Avatar
Beecher
I wouldnt get to concerned about having the drivers weight in the car, unless you are actually corner weighing the car. But by all means, do it if you can, but its not critical in a street car. If you like to autox or track, then i would go out of my way to have no preload (i remember the days of my car turing tighter one way than the other, hahah).
Beecher
Debi's Coop S
Dec 27, 2015 02:35 PM
vulkandino
Oct 31, 2015 08:29 PM
Joeygonz
Oct 4, 2015 09:25 PM
Debi's Coop S
Oct 3, 2015 07:49 AM
gnhovis
Sep 28, 2015 06:28 AM
