Suspension Swap out trany need help
Old Jan 15, 2007 | 05:04 PM
lifeinbemidji's Avatar
lifeinbemidji
I have located a 6 sp manual trany to replace my 5 speed manual that is making noise. what problems will I run into swaping the 6 sp in place of the 5 sp? are the axels the same? are the clutch plates splined the same? will it bolt in OK ? the shifter and linkage for the 5 sp , will it work for the 6 sp?
If you know or have done this please advise.
Paul
Old Jan 15, 2007 | 08:55 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
Send me an email and I'll go over the list. It will take more than just the tranny. I'm currently working on this project.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Jan 16, 2007 | 07:46 PM
lifeinbemidji
Trany swap
I am glad I am not the only crazy person...
My Email is Paul.L.Nelson@NTCmn.edu
I teach in the High Performance Engine Machinist Program here at Northwest Technical College in Bemidji, Minnesota where it is always warm and sunny..
Would you have an extra 5 sp for a 03 laying around that is in good shape??
Mine makes noise in 2nd, and 3 rd gear, that is why I am looking at the swap, if I could find the correct trany I would rather just put a 5 sp back in.
Any help would be great.
Paul
Old Jan 16, 2007 | 09:30 PM
Vendor
That's the same reason we're doing the swap. This trans makes the noise in all gears.
Old Jan 16, 2007 | 09:37 PM
002's Avatar
002
what kind of noise? Is it gear noise during hard decel?
Old Jan 16, 2007 | 09:44 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
i know for a fact that you will need a clutch/flywheel combo to fit the new trans.. but you may run into the flywheel bolting to the crank problem, and maybe even a starter issue. you will also have to run the drive shafts. they are all different. some S shift linkage and maybe a shifter and maybe a slave cylinder and you're good to go......
what i really want to see is a CVT to a 6 speed swap. now there is some fun.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
elverado
Jan 18, 2022 02:51 AM
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
shadtree
Cooper (non S)
Sep 8, 2016 12:02 PM
B1mm3r101
Oct 1, 2015 06:22 AM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
