Suspension Adjusting sway bar
Old Jan 14, 2007 | 07:22 AM
qwertmonkey's Avatar
qwertmonkey
Adjusting sway bar
Sorry, I have a very dumb question.
I'm about to put on my Progress 22mm Sway bar. (Its -8 celsius here so I'm not exactly thrilled.)
I've been searching for the past hour trying to find the answer to my very easy question. My bar has 2 adjustments. On on the end of the bar, and one closer to the center. (One toward the front, one toward the back of the MINI.)
Which one is the softer setting?
Sorry, I searched, but could not find the answer anywhere!!! :impatient
Old Jan 14, 2007 | 07:27 AM
mitchman's Avatar
mitchman
The softer setting is the one that gives you less leverage. The holes should be at the ends of the bar, so using the holes furthest from the bend are the softest setting. Again, the softer setting is the one the gives you less leverage.
Hope this helps!
Old Jan 14, 2007 | 07:45 AM
snid's Avatar
snid
The hole further out / closer to the end is the softer setting.
Old Jan 14, 2007 | 09:55 AM
kenchan's Avatar
kenchan
using no endlinks is your softest setting.
youve never broken a pencil when you were a kid?
try breaking a pensil that's full length and also shorter
length. tadaa.. same thing.
dropnstylez
Oct 29, 2015 08:57 AM
atlantaorange
Sep 16, 2015 12:43 PM
AHE3
Sep 16, 2015 06:32 AM
Suspension Products
Sep 2, 2015 10:32 AM
