Suspension 06 Poly Engine Bushing??
Old Jan 11, 2007 | 05:31 AM
Drillslinger's Avatar
Drillslinger
I've searched and can't seem to find any info on whether or not anyone makes a polyurethane motor mount bushing for the 2005/06 MCS?? I've found a LOT of places that offer Engine Bushings like this one at Detroit Tuning:
They just don't look like they'll work on my Motor Mount
I AutoX in the STX class and have found in the rules where I can replace bushings or add non-metallic inserts, but I'm pretty sure adding the "Engine Damper" wouldn't be allowed.
Any thoughts/suggestions?
Old Jan 11, 2007 | 08:49 AM
shoeboy's Avatar
shoeboy
You may get more feedback in the STX Forum:
https://www.northamericanmotoring.co...splay.php?f=55
Old Jan 11, 2007 | 08:55 AM
dave's Avatar
dave
pug poo picker-upper
Thread moved
Old Jan 11, 2007 | 09:31 AM
Drillslinger
Uhh, OK. STX forum it is then, although the question is about the bushings and not the rules
Old Jan 11, 2007 | 09:42 AM
dave's Avatar
dave
No problem. I'll move it back and leave a link then. I thought you might have a rules question about it too.
Old Jan 11, 2007 | 09:57 AM
Drillslinger
I'm getting dizzy
What I'm trying to find out is which, if any, polyurethane Motor Mount Bushing will fit/work on the 2005 and 2006 Motor Mounts. These things look WAY different than the pics I've seen of the earlier mounts
Old Jan 12, 2007 | 05:04 AM
Drillslinger
So... nobody knows then??
Old Mar 28, 2007 | 12:33 AM
YakiMini's Avatar
YakiMini
Originally Posted by Drillslinger
I'm getting dizzy
As far as I know, the bushings should work on all pre-07 Minis.
I just picked up a set this weekend and noticed a difference on my 02' MC immediately. Here are pics for all who may be interested
I picked up my set from Mini-Madness http://www.mini-madness.com/index.as...ROD&ProdID=110
They suggest that install time is about 1 hour but I was done in about half and hour. (use channel-lock plyers to remove the OEM rubber bushing and also use the plyers to align the bracket so the bolts will go into place.) just my 2 cents
Old Mar 28, 2007 | 05:13 AM
cristo's Avatar
cristo
Alliance Member
powerflex makes 'em as well
www.powerflex.co.uk
http://www.powerflex.co.uk/products....19&submit1.y=9
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
Aug 21, 2015 10:07 AM
minipopkart
Aug 13, 2015 05:22 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
