Suspension sheared off dinan strut brace bolt, now what?
Old Oct 29, 2006 | 05:08 PM
dandman's Avatar
dandman
hi
i borrowed a freinds torque wrench to tighten the dinan strut brace i bought(used) all bolts were fine, one just sheared right off, i was wondering if i can drill it out and put another bolt
also, stripped the strut bolta bit (one of three) its holding, but the metel sure is soft, and i had the torque wrench set for 20 ft lbs, then my next setting would be proper 24 fl lbs
not impressed, with torque wrench or strut brace (and yes, the torque wren ch was tested earlier)
thanks
dan
Old Oct 29, 2006 | 06:38 PM
dkstone's Avatar
dkstone
Originally Posted by dandman
hi
thanks
dan
Yes no choice but to drill it out, I would then find a set of bolts that is one size larger and tap all six holes to one size large and all should be OK.
Old Oct 29, 2006 | 06:44 PM
trackster's Avatar
trackster
You could drill out the bolt and replace it with a bolt / nut. the only issue is when you want to install or uninstall it as you almost need a second pair of hands. I survived like that for several months with no issues.
Old Oct 29, 2006 | 07:26 PM
dandman's Avatar
dandman
hi
can the strut bolt be taken out, or do i have to remove strut to replace it?
its holding, just a few threads gone, ill drill out the strut brace one
thanks
dan
Old Oct 29, 2006 | 07:38 PM
Yucca Patrol's Avatar
Yucca Patrol
The replacement strut mount is a cheap part (about $30). I'd go ahead and just buy a brand new one since you'll have to dissassemble the suspension to put a new bolt into the mount.
Old Oct 29, 2006 | 07:47 PM
trackster's Avatar
trackster
hi
thanks
dan
In my case the actual bolt itself pulled out so the hole was ready and waiting .
patsum
26
May 29, 2021 06:29 PM
M7Speed
Sep 4, 2015 10:47 AM
Suspension Products
Sep 3, 2015 09:41 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
