Suspension Since i raised my '04 MCS...
Old Sep 5, 2006 | 04:42 PM
modified mini's Avatar
modified mini
I don't get that mild steering wheel vibration at 40mph-75mph. I believe its from the axles being a tad too long.
Anyone want an '04 blk/blk leather int. MCS. Its for sale.
Old Sep 5, 2006 | 04:49 PM
goldcountrymini's Avatar
goldcountrymini
What were you running before? Did you put it back to stock? What is your aprox ride height?
Old Sep 5, 2006 | 11:02 PM
modified mini
its stock ride height now. i had the same problem with my civic when i first did a swap. I used a tad bit longer axle. When the car was at stock height it was fine. But as soon as i lowered it. I ran into axle problems. So i had to shorten it.
Old Sep 5, 2006 | 11:10 PM
modified mini
I just think with a shorter axles. Vibration would be gone. And one thing i notice is on the 2002-up honda civic hatchback/ and RSX. When installing lowering springs. i have to support the whole steering knuckle with a jackstand. if i don't, the axles would pop out from the inner joint. And when i lower my cooper. i just let the whole unit hang. And I can pull and tug on the hub and the inner axle would not pop out of the joint.
I wouldn't recommend anyone doing this. If it does pop out, the whole axle would have to come out and realign the bearings to the cup. pretty messy job.
Old Sep 6, 2006 | 01:53 PM
goldcountrymini
Did you replace the entire axles or just the springs?
Old Sep 6, 2006 | 03:07 PM
modified mini
I just put my car back to stock suspension since i'm trying to sell it. I would experiment with the axles, but i don't want to work on the car(kinda lazy).
M7Speed
Jul 10, 2018 09:26 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
gnhovis
Sep 28, 2015 04:07 AM
Keet
SCCA Solo and ProSolo
Sep 20, 2015 01:02 PM
Keet
Sep 19, 2015 09:45 PM
