Suspension Are you bump-stopping...
Old Aug 30, 2006 | 11:15 AM
  #51
Dr Obnxs's Avatar
Dr Obnxs
Then it's a bad design...
no complience is fine for the track, but real bad for the street.
And if it's an old track with lots of patches, then no complience isn't that good their either.
Matt
Old Aug 30, 2006 | 11:26 AM
  #52
BFG9000's Avatar
BFG9000
They have really convoluted scallops cut out of them for compliance. The newer urethane foam ones can be even more compressible, but of course have the disadvantage of varying rate based on temperature and humidity!
Old Aug 30, 2006 | 12:01 PM
  #53
meb's Avatar
meb
Okay, we're sort of off topic. But these were developed for road cars and specifically for compliance. I feel they may have an application on the street as well. Twas my only reason for bringing these up. These are in fact in application all over the world currently - I'm told.
Old Aug 30, 2006 | 12:51 PM
  #54
BFG9000's Avatar
BFG9000
I don't think it's really OT given the title and original post:
Originally Posted by TonyB
I have a feeling, and I hope that I'm wrong, that many are bump-stopping and not knowing it...
My stock height MCS has about 1" from the top of the front strut housing to the solid rubber part of the bellows under the bump stop. So if you've lowered your MCS more than that you are probably riding on the bumpstop all of the time and don't know it. The compliance part is why you don't know it. Fortunately, the original post also offers a way for you to find this out for yourself:
a simple putty test is an easy and cheap way to see if one is bump-stopping.
We can probably conclude from this limited free travel that the MCS is designed to corner on its bumpstops like nearly all other modern sporty cars.
Old Aug 30, 2006 | 01:07 PM
  #55
TonyB's Avatar
TonyB
BFG9000, you are spot-on, thank you. It's nice to see you participating, along with the likes of Dr O, Petrich, meb, 002 and others who I've learned so much from! The original title of this thread read something like 'Are you bump-stopping... and are you aware of it?', but I guess it somehow got edited...
The PSS9's have internal bumpstops, so the putty test no longer does it for me, unfortunately. While I know I'm doing better now than with the Ledas, I plan to increase travel about .75" when I go with the new H-Sport camber plates. I might also go with a slightly stiffer, linear springs (350#). The PSS9 progressive rate front springs are rated at 320# I think, so this increase in spring rates won't really help that much. I do so really to get more negative camber as the barrel springs are the limiting factor here...
Old Aug 30, 2006 | 01:42 PM
  #56
meb's Avatar
meb
Hey tony,
I've never used putty, but a zip tie works very well...and is typical racing equipment for such experiments . Install the zip tie just below the bump stop - touching it. Take the car for a ripping ride. check the new location of the zip tie...this will tell you how much travel you are using. But like BFG9000 wrote, the Mini is designed to ride these. The Megan bumpstops by contrast are very hard!
Old Aug 30, 2006 | 01:50 PM
  #57
TonyB's Avatar
TonyB
Thank you Michael. Tried searching for a photo so I can have a visual of this, although it sort of makes sense. In my situation though (PSS9's), the bumpstops are inside...
Old Aug 30, 2006 | 05:26 PM
  #58
obehave's Avatar
obehave
Originally Posted by meb
Doc, is Dinan authorized to perform revalving work? I'm under the impression Trueshoice is the only authorized rebuilder in the USA?
Preventing bottoming is the product of good suspension design. You do not necessarily need a heavy spring to prevent this, just lots of suspension travel. And if your car does touch the bumpstops on the track or during hard cornering, the car will begin to slide at the corner that has lost travel. This will also cause some very weird braking problems; if both front struts make strong contact with the bumpstops during threshold braking, watch out. This happend to me at LRP a few weeks ago while passing a friend deep into turn 1 from the straight
Just curious.
There is also a school of thought that well designed bumpstops are actually an important aspect of suspension tuning.
Overly rigid springs have their own issues and running springs firm enough to prevent that may actually be too high a rate. Allowing the suspension to settle onto a compliant bumpstop allows a softer spring but prevents any coil stacking.
This is not an endorsment one way or the other but is worth discussion I think.
This doesn't reference both stops bottoming under severe braking.
Just curious meb. Was this a rough corner where you may have experienced rebound stacking due to a too slow a rebound rate?
Old Aug 31, 2006 | 05:24 AM
  #59
meb's Avatar
meb
The left hander at Lime Rock - not rough unless contact is made with the considerable rumble strip...since I do not race for a living, nor am I a suspension engineer, I had to drive a few laps before I could determine what was happening. I kept questioning myself while driving, "am I running out of camber, where's all the grip?" Then suddenly I realized this was not so much a progressive loss of grip as it was sudden. So I focused and really hammered the turn to repeat and sure enough...
Before the next session, I upped the Megan damping by 6 notches - from setting 20 to setting 26 - and I could have gone higher. Setting 32 is max - these have obviously worn a bit.
michael
