Suspension Rear sway bar opinions
sorry for the hi-jack, but them FSDs are getting good words nowadays...
Originally Posted by Stevie B
H&R 19mm on stiffer setting! It's a mount and forget accessory. Transforms handling. Since I live in Germany, I drive very fast. I wouldn't dare go beyond 19mm as it only increases the odds of the rear stepping out in an emergency maneuver. Plus, the 19mm H&R is absolutely confidence inspiring. Delivers very neutral cornering. Combined with FSDs, it's what the MCS should have come with. Total transformation of handling/cornering and dramatic improvement in ride quality.
Stock rear bar ( Looks stock? )
I started looking at rear sway bars also. The front of the car does understeer a lot. Which rear bar looks the most like the stock rear bar. ( I like the stealth look. ) Don't care adout the color, that can be changed with some sandpaper and rattle can. Also has anyone removed there stock "S" springs and install the reg. Cooper springs on a "S"?
There sould be 4 or more stock spring sets for the Mini. Reg. Mini & rag top, Auto & 5spd and so on does anyone know?
Thanks...........
There sould be 4 or more stock spring sets for the Mini. Reg. Mini & rag top, Auto & 5spd and so on does anyone know?Thanks...........
Either the H-Sport comp bar or the WMS Preferred line. Both are black. The nod would go to the H-Sport as it has no clamps for lateral movement, just like the stock bar.
Hope that helps!
Randy
Hope that helps!
Randy
Originally Posted by The MINITOR
I know that this has been asked many times, but did not see it being answered recently. I still have yet to put on a rear swaybar. For street use what are the best ones for the money? I don't want to go the Exreme Swaybar $400+ route. What's the best and what size? Thanks.
Hope that helps!
Randy
Hope that helps!
Randy
Where would you place the end link on the H-Sport bar if you wanted a street car that was more neutral, with just a little understeer? We have changed out the run-flats with a 215/45-17 Fuzion ZRi. I did some reading and this tires looked better than the Yok's AVS ES 100. ( I even put a set of 265/50-20 on my Nissan Frontier crew cab truck, they are far better than the Toyo's I had! )
Can you make a recommendation on where to place the end link on the bar?
Thanks for your time!
Sure, but you're going to use us to buy the bar now, right
For what you are looking for - still a bit of understeer - I would use the softest setting. That's the farthest from the front of the car.
Hope that helps!
Randy
?For what you are looking for - still a bit of understeer - I would use the softest setting. That's the farthest from the front of the car.
Hope that helps!
Randy
