Suspension What to do if my coilover ceased?
Yes, my very question Ryan.
This may sound a bit, well, farmish. Spraying diesel fuel on and in and around the perch threads and other parts before winter will help for sure. When the volatile portion of this fuel evaporates, a protective parafin residue remains. Farmers still use this technique today on equipment left outside for the winter.
Or, just lubricate these parts once or twice during the winter with any high film strength lubricant.
Originally Posted by Ryephile
I'm interested to know what seized; the piston doesn't move in the shock body, or you can't adjust the spring perch?
I 2nd the PB Blaster being the hot stuff
Originally Posted by larkie
oh, should i ? r u serious?
lubing tends to loosen the seat locks which i would
not want to do on a coilover system. What I did was
clean the seat locks using some RC car nitro engine/
electric motor spray, then e-taped the coil. ive
never had one seize. that parafin protectant sounds
like a great idea. :smile:
Unfortunately, we see this all the time...that's why we favor KW
Normal routine would be soaking them in penetrating oil (castle thrust) and moving them back and forth...applying slight heat as well (not open flame, heat gun).
but i heard that using heat to do it, might kill the shocks or something... is it?
any air that might be in there and damage the seals resulting in a leak.
How bad is the ride height on your car with that seized coilover?
might be eaiser to just corner weight the other 3 to match.
sssevita
Mar 20, 2016 06:24 AM
