Suspension NEW RELEASE: Dinan 3rd Gen MINI Wheel Spacer Kits & Lugs
Part Number(s):
- Spacers: D210-2020 through D210-2031
- Bolts: D220-0001 through D220-0007
- ALL 3rd Gen MINI's (F54, F55, F56, F60)
Release Date: Available Now!
Description: Dinan's Wheel Spacers physically move the wheel further away from the hub. In doing so, they give your wheels the desired offset needed to create the stance or look you desire, or clearance necessary to clear brake calipers.
When using wheel spacers, longer bolts are required. As such, appropriate length bolts for each kit are also available and linked on each product page.
Features/Benefits:
- CNC-machined aluminum.
- Weight saving design.
- 66.5mm center bore configuration.
- 5x112 bolt pattern.
- Available in sizes ranging from 2mm to 20mm thick.
- Hub-centric rings on larger spacers.
- Anodized black.
- Set of 2.
pfunk
Tires, Wheels, & Brakes
Feb 16, 2006 09:33 AM
