Suspension R53 front sway bar endlinks hitting axle
SuspensionSprings, struts, coilovers, sway-bars, camber plates, and all other modifications to suspension components for Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
Hi guys, looking for some input on what I should do to fix the front sway bar endlinks from hitting the axles. It's on both sides. Car is lowered 1.5 all around. Do I need adjustable endlinks or is there something else I should be looking for? I will try to get better pictures today. Thanks!
those appear to be some aftermarket end links that are made wrong as they are too big on that end. You unfortunately can't put it on the otherside of the bar as it then won't fit the strut.
Thanks for the heads up about not being able to flip them. My sway bar is angled very far down like 45 degrees. So I’m thinking I should get adjustable end links.
