Suspension Rear Camber Settings
Old Jun 14, 2016 | 03:15 PM
slimjimtell's Avatar
slimjimtell
Can someone shed some light on this??
I have a 2010 Clubman S
What is the OFFICIAL rear camber setting for this car?
I just had mine aligned at MINI they set it to -2.17 I think it is TOO much neg camber and I don't want to scrub the inside of the tires off. I have hotchkis adj control arms on Megan Coilovers.
I have seen the spec to be -1.45 +/-.25
They said the MAX spec is -2.2 for JCW sport and -2.04 for cooper S
It's all over the board!!!!!!!!!
I want a street setup to get good tire wear with a little better performance.
HELP! They are willing to put it back on the rack to give me what I want. I think it should be between -1.5 and -1.75
Old Jun 14, 2016 | 04:27 PM
Mini Mania's Avatar
The Bentley Service Manual lists the following:
Standard & Sport Suspension -1 degree, 45' +/- 25'
Sport low-slung suspension -2 degrees, 00' +/- 25'
Hope this helps!
Old Jun 14, 2016 | 05:14 PM
slimjimtell
So, if I can get them to bring it back to -2 or just below, I'm good? I would rather it NOT be on the high side which is where it is right now.
Old Jun 15, 2016 | 02:49 PM
Mini Mania's Avatar
Yes, and keep an eye on tire wear to make sure it's evened out.
Old Aug 20, 2016 | 01:30 PM
obdoesit's Avatar
obdoesit
is it possible to adjust the rear camber without adjustable control arms?
Old Aug 20, 2016 | 04:45 PM
cristo's Avatar
cristo
Alliance Member
I believe the stock arms have an eccentric bolt that gives you a
measly 0.5 degree range of adjustment. See if there's enough
there to help a little.
guiltless
May 5, 2016 12:59 PM
dube53
R58 :: Coupé Talk (2012+)
11
Mar 24, 2016 05:14 AM
JWA
Mar 20, 2016 07:24 AM
JWA
Mar 20, 2016 06:41 AM
midwestinsocal
Mar 18, 2016 10:35 PM
