Suspension Help! Is this an ALTA PSRS Bushing?
Old Apr 11, 2012 | 08:21 PM
jschnelk's Avatar
jschnelk
Hoping I can get some help here. Below are pics of the driver's side lower control arm bushing on my 2005 MCS. Is this an ALTA PSRS Bushing?
I'm getting a lot of rattle in the front as I go over bumps. I was going to replace these bushings with Powerflex bushings. Now I'm thinking this is a better set up and the rattle may just be that these allen bolts holding the sleeve to the control arm need tightened or the whole setup needs lubricated.
It looks like the system, but I am confused by everything being painted red. There is also a part number "11B04" stamped on the bracket.
Help and info identifying these would be much appreciated. Thanks!
Old Apr 12, 2012 | 03:04 AM
HRM's Avatar
HRM
It doesn't look like an alta to me, but is doesn't look stock either so someone who has been around a while will have to think back.
My thoughts are that you may want to have the replacement bushings ready (you can sell them if you don't use them) and take a good look at this once it is apart. Something like this should have zero play in it and if you get it in your hands and it has slop (from running un-greased it might be worn out) you will have the parts to get on the road the same day.
Old Apr 13, 2012 | 07:36 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes those are the Alta bushings, the end of the shafts have been welded to the centers, and then they painted it all red
Old Apr 14, 2012 | 07:00 PM
jschnelk's Avatar
jschnelk
Do these need to be lubricated periodically? I'm getting a lot of noise up front going over bumps. I had the MINI on a lift last week and there was a slight click from these bushings under load.
YaTuSabe
Aug 23, 2018 11:41 AM
Debi's Coop S
Dec 27, 2015 02:35 PM
vulkandino
Oct 31, 2015 08:29 PM
pahg
Oct 5, 2015 11:50 AM
Debi's Coop S
Oct 3, 2015 07:49 AM
