Suspension lowering question
Old Dec 2, 2010 | 02:11 PM
ryanschram's Avatar
ryanschram
lowering question
when lowering on springs (not more than 1.2inches) will adjustable rear camber arms still be necessary on an 06 MCS?
Old Dec 2, 2010 | 03:20 PM
iwashmycar's Avatar
iwashmycar
probably not. an alignment cant hurt, and while the 1st gens tend to go toe out a bit when lowered, 1.2 isnt much
Old Dec 2, 2010 | 04:47 PM
quikmni's Avatar
quikmni
Depends on how much negative rear camber is acceptable to you. With a 1.2" drop and stock control arm adjustment you will probably be around neg 2.5 degrees.
Old Dec 2, 2010 | 05:20 PM
ryanschram's Avatar
ryanschram
thanks, -2.5 is way too much for a DD. If this was for a dedicated track car, that would be fine.
Old Dec 2, 2010 | 05:45 PM
andyroo's Avatar
andyroo
1.2 is a lot for these cars on springs.....they have very little bump travel. I guess we're talking about different things though.
-2.5 in the rear is too much for the track.
Sorry, I've had a rough day. Yes get rear control arms and dial in -1.5 or a little less rear camber for better handling and tire wear. You must get an alignment either way.
- andrew
Old Dec 2, 2010 | 06:19 PM
ryanschram's Avatar
ryanschram
- andrew
thank you
Old Dec 6, 2010 | 09:37 AM
quikmni's Avatar
quikmni
Even with the 5/8" drop of the JCW suspension on my 06 MCS, I can only reduce the amount of rear negative camber to about negative 1.5-1.6 with the stock adjustment. So if you drop any lower than about 5/8" you will need aftermarket adj lower control arms to get the negative camber into the -1.5 range that is prefered by most people.
silence2-38554
Nov 12, 2015 09:39 AM
loop4re7
Oct 5, 2015 09:53 PM
G1HQ
Aug 28, 2015 01:41 PM
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
