Suspension Thinking BC
Old Jun 11, 2009 | 09:53 AM
  #26
Ryephile's Avatar
Ryephile
It's just a spherical bearing; it transfers load to its carrier. The damper shaft gets no loading except its intended compression loads. The stock bushed carrier however does add a bending load to the shaft as the shaft is used to deflect the bushing. The BC design is superior in decoupling the shaft movement from the chassis, NVH notwithstanding.
Old Jun 11, 2009 | 07:23 PM
  #27
miniman101's Avatar
miniman101
Hey, the Cross coilovers say they work on R53 and GP models. They will also go on my R50 without a problem won't they?
Old Jun 12, 2009 | 01:43 AM
  #28
ninjlao's Avatar
ninjlao
Ninja Mini
The flat top hat transfers more stresss through the spherical bearing into the damper shaft, which can lead to damper failure during extreme stress. To say that BC Racing has done "more homework" than Endless when it comes to suspension tuning is a pretty ridiculous statement.
I just want to point out the fact that Mini Cooper suspension assembly is probably a mistake from the factory. I believe that MINI made the chassis first and then ordered the suspension techs to make the suspension around the construction of the chassis. This is why the rear suspension is such a problem. If you look at the stock suspension the construction of the suspension mounts are completely horizontal, and the suspension is forced to come out at an angle to connect to the arms. You can tell it's a mistake because Mini try to cover it up by putting in a huge rubber bushing
Now your saying that the BC has enough movement in the suspension assembly. I know that they do not make them properly. So I have to hear what makes you think they are efficient. Ill give you a lowdown real quick on heim joints, which keep in mind are a vital part of any suspension. For example you would probably know this best if you were to drive a 240sx but they sell a whole mess of arms and rods on ebay, Stuff that usually costs about 300 dollars now can be bought made in China for about a little less than 100 the more popular companies are Megan and TC Sportline. Well I actually do not have a problem with these, except for the fact that the Heim joint (spherical bushing) blows out after a couple months of driving. The good thing is that you can replace the bushings with better well known american made ones. They will eventually wear out also but will last you a few years. You will notice that these bearings most of the time looks the same, that is because the casing around it is essential for a Heim. In other words the spherical bushing generally has a 20% max range in motion to be safe. anything beyond that has too little contact with the ball, the movement in the bearing isn't much at all(at least not for the movement of the mini shock). If those BC plates clears it definately either has more than 20% movement or it barely fits and will hit from the coilover. I know the topmount is nowhere near slanted enough.
And if they were to think that angling out the heim joint in the top mount would work they are also dead wrong about that. This is where the shock shaft would be too stressed and will snap, this is what Endless did thinking it would work. BC didn't go that far, in my opinion they just tried to make anything that worked. Look at the picture of the BC coilovers on the first page, they look nothing like the stock top mount, they look like Generic topmounts that just happens to fit on the Mini. They are not a bad set for the price, I even bought it to check it out, but then again I don't expect much from Chinese made suspensions.
The only way to make it work is to make a top mount that either looks exactly like the stock with a tilted heim joint, or What I am going to be doing, which is modify my frame, build up on it and make it sit like the way the Mini should have been designed.
Old Jun 12, 2009 | 07:44 AM
  #29
miniman101's Avatar
miniman101
Stop arguing you little girls. Its not the end of the world.
And oh, never mind my last question. I found the answer.
Old Jun 12, 2009 | 11:25 AM
  #30
Ryephile's Avatar
Ryephile
What kind of stress? Spherical bearings inherently eliminate bending loads because they articulate. What do you mean by "damper failure during extreme stress"? Are you saying the damper shaft with snap? This can only occur if the spherical bearing binds beyond its range of motion
So what? The mount does not have to be tangential to be effective.
I know that they do not make them properly. ....the Heim joint (spherical bushing) blows out after a couple months of driving. ..... I know the topmount is nowhere near slanted enough.
If they're not made correctly, why aren't there any known failures? Your sweeping generalization that spherical bearings must "blow out" is a gross mischaracterization. They typically fail due to negligent maintenance, lack of lubrication, or exceeding their articulation parameters.
And if they were to think that angling out the heim joint in the top mount would work they are also dead wrong about that. .... but then again I don't expect much from Chinese made suspensions.
You keep contradicting yourself. Your idea to make the mounting hats tangential is a waste of time, there's nothing wrong with the current BC setup. The only improvement will be less shearing force on the mounting bolts going from the mounting hat to the chassis. If you think saving the couple pounds of force will save the day, more power to you. I'd suggest finding a more useful problem to solve, like the front roll-center problem on the R56.
Cheers,
Ryan
Old Jun 23, 2009 | 09:06 PM
  #31
miniman101's Avatar
miniman101
So after all this...
These are waiting to go on Friday!
Old Jun 24, 2009 | 09:30 AM
  #32
ninjlao's Avatar
ninjlao
Ninja Mini
NICE!!!
You wont be dissappointed.
Old Jul 8, 2009 | 03:00 PM
  #33
miniman101's Avatar
miniman101
Here they are!! I am very happy with them. A bit stiff, but its manageable.
I just put in new H-Sport lower control arms to suck in all that extra camber. Its perfect now!
Old Jul 12, 2009 | 01:02 PM
  #34
04indimcs's Avatar
04indimcs
One of the best coopers I've seen
Old Jul 16, 2009 | 01:07 PM
  #35
miniman101's Avatar
miniman101
Thanks...
I just try not to carried away like so many Mini owners do. People will, if they aren't careful, will start covering it with stickers and putting stuffed animals in the rear window and all. Thats basically my worst fear.
Its back to the black outs now...
Old Jul 16, 2009 | 07:59 PM
  #36
pauliekeys's Avatar
pauliekeys
The car looks great Miniman, Congrats, glad you got the coilovers installed!
Maybe you should go a click, maybe two softer. It took me a month of playing around with my set up to get it just right. I'm sure you'll find the right balance in time! Did you mount the extension cables? Kind of a hassle to set up but, it sure makes things a lot easier to adjust that's for sure.
Old Jul 16, 2009 | 10:47 PM
  #37
mini_macky's Avatar
mini_macky
& did you grind away at the top mounts? kinda wished i didn't on mine :(
Old Jul 17, 2009 | 01:47 AM
  #38
user 7082082's Avatar
user 7082082
You do not have to at all. I installed my BC coils last week (which btw I love) and the alen bolts can be swapped out for different bolts and be adjusted easily without any cutting.
Old Jul 17, 2009 | 02:39 AM
  #39
mini_macky's Avatar
mini_macky
well, the damage has been done
Old Jul 17, 2009 | 07:57 AM
  #40
pauliekeys's Avatar
pauliekeys
Yeah, no need to cut anything, Using T handled Ball end hex wrench will allow a person to reach the bolts for adjusting. Cutting the towers is unnecessary and way too permanent ! I was able to explain the "Ball ended Hex wrenches" to Miniman so, I'm pretty sure he didn't cut anything. I had never heard about changing the bolts before, sound like another safe non evasive way to reach the adjusting bolts! Hopefully this info will help others from having to cut their towers!
LordOfTheFlies
Oct 19, 2015 05:02 PM
yukinoinu
Sep 20, 2015 09:10 PM
Ladybug-S
Aug 27, 2015 09:33 AM
DWooderson
Aug 20, 2015 04:31 AM
rphox2003
Aug 5, 2015 11:34 AM
