Suspension Eibach springs vs TSW springs
Old Mar 25, 2009 | 05:40 PM
  #26
dwf137's Avatar
dwf137
i was a little worried about the camber as well...
Old Mar 25, 2009 | 06:00 PM
  #27
MoxieMini's Avatar
MoxieMini
Originally Posted by BostonR56S
First I was wanting the H&R's, then I heard about ride quality, then wanted the mach v's / eibachs for their less agressive drop, but now that i've got my summers back on (18's) I am reminded that my wheel gap really isnt THAT big when compared to the 16's I had on for the winter.
Anyhow, for those with the TSW- the drop seems mild enough that we may be able to get away with oem (sport) rear control arms? I know they have a little play in them to get the camber back close to 0, if not maybe -.5
Also, any needs for cutting bump stops or anything? I've heard some discussions on that from the more aggressive drops...
edit: ah, and yes, I am thinking about/leaning towards TSW's now. in addition, with a less of a drop, there is more stock shock travel, so longer/slower wear =p
The negative camber is visible on my TSW's, but you can still get a proper alignment without getting aftermarket RCA's. I'll be going in for an alignment in about 400 miles.
Old Mar 26, 2009 | 05:35 AM
  #28
a96bimmerm3's Avatar
a96bimmerm3
Yeah I've been lazy, no alignment yet. Going to buy my own tools and do it.
Make sure to put some fixed camber plates while you're in there. They're 100% worth it.
Old Mar 26, 2009 | 07:49 AM
  #29
MoxieMini's Avatar
MoxieMini
I do too much interstate traveling right now. As soon as that settles down a bit, I'm all over the IE camber plates.
Old Mar 27, 2009 | 08:05 AM
  #30
BostonR56S's Avatar
BostonR56S
Anyone with pics on 18's? I'm about to pull the trigger, just really want to see wheel gap change for an 18.
My wheel gap right now stock sport suspen. is probably right around a little less than 2". If I get a drop of 1" i'd be pretty happy, putting me in a <1" gap in New England with these crappy roads and winters, it'd be a good compromise imo.
Old Mar 27, 2009 | 08:36 AM
  #31
dunphyj's Avatar
dunphyj
i personally say go TSW... for 3 reasons:
1) Suspension geometry: you're not going to get great performance just from slamming your car like honda people. mini's have a very great sweet spot with just a 1 inch drop, after that you start messing with the suspension geometry. sticking with JCW and TSW will give you higher rates with linear set-up and not unnessesary drop.
2)Balance: if you take the ratio ( >1 is front bias, <1 rear bias, 1 is perfect 50/50) the stock springs have a bias of .71 (for an idea, most honda's are 1.6 bias)... the Eibachs at highest rate, not the lower springs, are .72... where as the TSWs are .86... WAAAY better, better balance, better feel... IMO anyway... some people love the tail out action. but with a better balanced car you can dial in and out your tail action by just adjusting the rear sway bar...
3) this is my personal belief, i say if a stock suspension has linear springs then aftermarket should do that too. it keeps the car in a similar feel... on top of that, suspension systems like coilovers mainly have linear springs two... i've seen maybe two with progressive... Koni comes to mind. but if you want the drop of eibachs and like the more cushy ride and stock bias then go for them. i just think with hard pot holes and any sudden changes in the road could make a big problem if you go from soft to hard spring suddenly... once again tho, just mho
hope that helped some!!!
Old Mar 27, 2009 | 08:37 AM
  #32
dunphyj's Avatar
dunphyj
p.s. the negative camber is just -.25 on the TSWs... nice enough to give you more grip but not overwear your tires at all
Old Mar 27, 2009 | 08:36 PM
  #33
etalj's Avatar
etalj
If i were to get TSW springs (1" drop), how much camber would i get at the front assuming I shove the shock towers in as much I can (I have the slots on the front shock towers that allow this)
Old Mar 27, 2009 | 09:07 PM
  #34
AutoXCooper.com's Avatar
AutoXCooper.com
about -0.4
Old Mar 28, 2009 | 05:17 PM
  #35
BostonR56S's Avatar
BostonR56S
ahhhhhhhhh dilemmas!
thanks dunphyj there were some good points in there to reinforce my thoughts.
Old Mar 28, 2009 | 06:57 PM
  #36
MoxieMini's Avatar
MoxieMini
Go with the TSW's. You'll be happy... I promise.
Old Mar 28, 2009 | 07:32 PM
  #37
richi0207's Avatar
richi0207
After going for a ride in a96's car with TSW springs and IE camber plates, I have gotta say WOOOOW I AM STUNNED! . Much better handling than my mini with H&Rs. I think I have whiplash from the ride earlier! j/k
btw I couldn't stop thinking all day today how easily your car corners.
Old Mar 28, 2009 | 07:35 PM
  #38
MoxieMini's Avatar
MoxieMini
So have we won you over??? You know you want that neutral handling.
Old Mar 28, 2009 | 07:37 PM
  #39
richi0207's Avatar
richi0207
Haha....hmmm....I love the drop on the H&Rs but LOVE the handling on the TSW...this is tricky...
Old Mar 28, 2009 | 07:57 PM
  #40
IzzyG's Avatar
IzzyG
Get coilovers- they'd solve both problems
Old Mar 28, 2009 | 07:58 PM
  #41
richi0207's Avatar
richi0207
Lol, I would love to get a set but thats alooot of money. I really have to get convinced to pull the trigger on something like that!
Old Mar 28, 2009 | 08:12 PM
  #42
MoxieMini's Avatar
MoxieMini
Izzy's right, but CO's are overkill for a daily driver, IMO. I went back and forth about them for a couple months before I decided that TSW's were the way to go. And personally, I like the stance more than that of the H&R's. It gives the car more a "sleeper" look. Not to mention that actually bottom out on the roads LESS than what I used to on the stock springs.
Also, there are a few CO's that use progressive springs... boo.
Old Mar 28, 2009 | 08:24 PM
  #43
richi0207's Avatar
richi0207
Can I get a better understanding on linear vs progressive springs because I don't know exactly know the difference between the two.
Old Mar 28, 2009 | 08:39 PM
  #44
dwf137's Avatar
dwf137
progressive springs get stiffer as your suspension travels.
linear springs don't.
Old Mar 28, 2009 | 08:45 PM
  #45
richi0207's Avatar
richi0207
Ahhh, makes sense, thx!
Old Mar 28, 2009 | 08:49 PM
  #46
MoxieMini's Avatar
MoxieMini
Yep.
I'd like to point out that it's not at all a bad thing that linear springs remain constant. Because they remain constant, your car's handling will be much more predictable than with a progressive rate.
Old Mar 29, 2009 | 06:03 AM
  #47
IzzyG's Avatar
IzzyG
The theory behind progressive springs seems sound; less stiffening for when you don't need it(straight line more comfort) and more stiffening when you do need it(at turns). Some issues encountered however are the springs losing the soft rate before the hard rate, and handling being unpredictable.
Frankly, I would like to see(or best case scenario design my own) CO system that adjusts automatically(user presets the different points) depending on the road and maneuver. I believe Mercedes was boasting about a similar design they have on their new smaller SUV.
Note: Sorry for going off topic. :X
Old Mar 29, 2009 | 06:45 PM
  #48
a96bimmerm3
no problem. The car is 100% neutral, and very easy to drive and scare passengers. I'm still tempted to do the cross coilovers as I sometimes start having some body roll issues (both inside tires screaming for dear life) when I push the car way too hard. That or maybe a 22mm IE bar, not sure yet.
Old Mar 30, 2009 | 06:10 AM
  #49
D-Unit's Avatar
D-Unit
How hard are we talking here?
I'm trying to decide weather or not to skip the springs and go with coilovers. How hard is way too hard in your opinion. Of course, if I don't really notice a whole lot of roll (I do, but it isn't completely unbearable), I probably am not pushing as hard as you. In that case, I may just save the dough and get the TSW springs.
btw i have the stock sport suspension plus a 19mm alta rear sway, and a m7 front strut brace.
Also, what kind of driving do you usually do? Daily driving that is. Most of my daily drive is highway. I have held off on the camber plates for fear of accelerated tire wear. What is your experience with this?
Thanks.
Old Mar 30, 2009 | 06:23 AM
  #50
a96bimmerm3
Thanks.
I do a lot of highway and haven't noticed any bad wear. I think I'm talking triple the posted speed limit on a 180 degree really tight left hander. I like taking turns fast and the car is RE TARDED on the highway (for going around traffic). The camber plates did a lot, the springs did the rest. Ask Richi0207 if I drive hard, I don't look at the speedo most of the time.
