Suspension Mini Madness front control arm bushings?
Old Jan 9, 2009 | 11:06 AM
  #51
AutoXCooper.com's Avatar
AutoXCooper.com
Originally Posted by onasled
It wouldn't, ...but a worn wheel bearing would stress a rear bushing, along with all the other suspension components.
so it's the egg and chicken issue, what came 1st? I'm not going to debate which comes 1st. My point was to warn you all that there is an issue and it needs to be addressed sooner then later to save you money. Also note bad bushings and or hub could lead to faster tire wear.
I don't sell tires.
Old Jan 20, 2009 | 04:48 AM
  #52
Bajanmini's Avatar
Bajanmini
Ok just got it alinghed yesterday and had a spin at the track and all i can say is WHOA sweet.Next in line is a set of poly suspension bushes of which these are included.Would it be realistick to install a zerk fitting and drill a hole through the bushing,i have a concern about it squeaking down the line one of the main reasons i like H-Sport.
Old Jan 20, 2009 | 05:04 AM
  #53
IanF's Avatar
IanF
Originally Posted by scruffylooking
IanF - How much does that tool cost? That saves a lot of time and labor.
Sorry for the tardy response... forgot about this thread...
It's NOT cheap. There are threads on the subject... (search: LCA bushings) I was quoted over $400... paid a bit less... I've used it enough times to justify the purchase, but for a one-time install, it'd be a tough sell. The tough part will be finding a dealer that will order it for you. So far, I've had good luck with Morristown MINI in NJ wth ordering special MINI tools, but I have to prepay for everything. I think ZD Mak is selling a similar tool for considerably less.
This reminds me that this Spring, I will probably have to drop the LCA's again to clean and re-grease the bushings. After a NE winter of salt and road grime, I want new grease in there. Oh joy...
Old Jan 20, 2009 | 11:32 PM
  #54
scruffylooking's Avatar
scruffylooking
Better late than never. Thanks for the reply.
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
minicoclub
Nov 11, 2015 07:25 AM
maestro39
Oct 27, 2015 02:38 PM
OutMotoring
Aug 6, 2015 09:32 AM
