Suspension adj rear control arms, any benefit?
Old Apr 1, 2008 | 05:55 PM
  #51
S-Driver's Avatar
S-Driver
Originally Posted by cmt52663
yep
no arms - Stock
1 arm - ST*
2 arms - SM
so that 2nd arm puts you up with the lions and tigers and bears as far as i know...
Ain't that the truth........ welcome to the class with modded EVO's and STI's. There is a limit to what mods will give you in return when your up against 300+hp and AWD....
Old Apr 1, 2008 | 06:06 PM
  #52
freeskier's Avatar
freeskier
so due to my pully i run with the bigger class anyways? if i do not run a pully and only one set of arms am i ok?
Old Apr 1, 2008 | 06:21 PM
  #53
ScottRiqui's Avatar
ScottRiqui
No pulley and only changing one set of arms might get you back down into STX, depending on your other mods.
Old Apr 1, 2008 | 06:46 PM
  #54
freeskier's Avatar
freeskier
ok, sorry i got sidetracked, back to control arms. how easy is the swap? what is needed?
Old Apr 1, 2008 | 07:20 PM
  #55
Dr Obnxs's Avatar
Dr Obnxs
Lowers are pretty easy...
uppers are a bit of a pain. Not much other than two big freaken wrenches! Also, I found that it's easier to put the adjustables in if the lock not is a bit loose, allowing you to rotate the head to be parallel to the bolt axis.
Matt
Old Apr 2, 2008 | 12:09 AM
  #56
ScottRiqui's Avatar
ScottRiqui
Even the inboard ends of the lower control arms can be a bit tricky, since it can be hard to fit a wrench into the tight spaces to loosen the attaching bolts. I made sure I had a wide variety of swivel-socket attachments handy, and once I broke the bolts loose with a 3/8" ratchet, I switched to a tiny 1/4" ratchet to loosen them the rest of the way, since it was easier to work with the smaller ratchet.
Old Apr 2, 2008 | 03:14 AM
  #57
cmt52663's Avatar
cmt52663
you are right, the pulley puts you in SM anyway
que sera...
i spent my first year in the JCW Cooper is A Street Prepared due to the works kit and survived (barely)
honestly autox is fun and the class does not matter 'less you're trying at the national level - just check your progress against yourself and other folks with similiar performance
good luck with the back end and i wish you balanced handling!
Old Apr 2, 2008 | 06:28 PM
  #58
S-Driver's Avatar
S-Driver
Yeah, it's tight up in the inboard side of the arms...but can be done with just a swival adaptor and short socket, and open/closed end wrench. At first I was like "OMG"! But it went pretty easy in retrospect.
If you go for the uppers then just get 1 or 2 hose clamps, a piece of a bike inner tube, and a "L" bracket from the hardware store for the headlight aiming switch thingy. Can post pic if needed...
Old Apr 2, 2008 | 07:04 PM
  #59
S-Driver's Avatar
S-Driver
Here's a link to an SCCA approved/not approved mod list for autoX....
Old Apr 4, 2008 | 06:40 AM
  #60
freeskier's Avatar
freeskier
i will be doing the lower control arms and rear sway bar at the same time, will the order of install make it any easier? which first?
Old Apr 4, 2008 | 06:47 AM
  #61
Dr Obnxs's Avatar
Dr Obnxs
Here's an easy answer...
it doesn't matter.
Matt
Old Apr 4, 2008 | 07:16 AM
  #62
freeskier's Avatar
freeskier
ok sounds good, pull the old ones out and throw the new nes in. thanks
Old May 16, 2008 | 07:21 PM
  #63
101101's Avatar
101101
That's a little out of date, I wouldn't trust that site. I know Update/Backdate isn't legal for ST*. I didn't look further past that except to look for a "last updated" date.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
wkp1219
Nov 13, 2015 07:52 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
