Suspension Bilstein or Koni opinions
Old Apr 20, 2008 | 03:20 AM
  #26
heyitzsushiboi's Avatar
heyitzsushiboi
i've had my koni yellows for a week now and they're pretty nice. can someone show me how to adjust the rears? they seem a bit too stiff for my liking.
Old Apr 26, 2008 | 03:26 AM
  #27
heyitzsushiboi
someone help me please! and is it true that there are three settings that you can place the koni yellows? one is high, mid, and low?
Old Apr 26, 2008 | 05:43 AM
  #28
hemiheaded18's Avatar
hemiheaded18
The rears have to be removed for them to be adjusted. Unfortunately, they're not like the fronts where can just dial a ****.
I think there's more than 3. Isn't like 6 or 7 if not more? But basically, the higher you go, the stiffer and harder the valving.
Old Apr 26, 2008 | 03:27 PM
  #29
heyitzsushiboi
I'm sorry i asked the question incorrectly. are there three different perch settings, so that the springs will sit higher or lower on the shocks themselves, therefore giving the car an extra drop or not such an extreme drop?
Old Apr 26, 2008 | 03:34 PM
  #30
Justanthony's Avatar
Justanthony
they are not height adjustable
Old May 8, 2008 | 07:06 AM
  #31
Wookie's Avatar
Wookie
Where the Koni's require "modification" and need to be removed entirely to adjust the rear (meaning most won't go through the effort to adjust them) - is there any benefit or detriment to running Bilsteins in the back and Koni upfront?
Old Nov 20, 2014 | 09:55 AM
  #32
cristo's Avatar
cristo
Alliance Member
Revisiting this thread for hopefully some more opinions, specifically comparing Koni Yellow vs Bilstein Sport.
Anyone have experience to share with either or both of these on stock height springs for a R50 or R53?
I actually like the early OEM SS+ struts/shocks on my R50 (same part as the R53 ones), and at 82K, they're still holding
up surprisingly well, but since MINI softened them up in 5/2003, I feel the currently available ones would be a step
away from what I'd prefer.
Old Nov 24, 2014 | 10:44 AM
  #33
andyroo's Avatar
andyroo
I will be removing my Koni Yellows for a set of custom valved Bilsteins very soon. I'll give some feedback when I do.
- andrew
Old Nov 24, 2014 | 11:03 AM
  #34
deovolens's Avatar
deovolens
Long ago I bought original KOINIS made by the dutch company.The quality is not the same then long ago.I bought for my Mini Ohlins in 2007, the quality and finish were excellent ,the ride got better and smoother.
Old Nov 24, 2014 | 11:28 AM
  #35
cristo's Avatar
cristo
Alliance Member
Interesting product. Much lower drop than a traditional coilover (15 mm).
Can the preload be adjusted closer to stock height?
Pretty pricey, though ($2324 for the 4). I'm not sure I can afford quite that much.
Old Nov 24, 2014 | 11:30 AM
  #36
cristo's Avatar
cristo
Alliance Member
- andrew
What custom valving did you choose and why?
and who does the custom valving?
Old Nov 25, 2014 | 10:28 AM
  #37
cristo's Avatar
cristo
Alliance Member
Found a neat summary page on the Ohlins coilovers:
http://www.improvedracing.com/coilov...0r53-p-45.html
They also have a tab for an instruction pdf.
343 lbs/in front, 286 lbs/in rear
front height -35mm to -5 mm c/w stock
rear height -40 to -10 mm c/w stock
rebound adjustable
and more.
there's also a page for r56 applications,
which is a little less expensive, a bit stiffer, and a little taller.
http://www.improvedracing.com/coilov...r56-p-357.html
Old Dec 2, 2014 | 11:19 AM
  #38
andyroo's Avatar
andyroo
I sent them to Bilstein USA in CA for the revalve.
I asked for 70% critically damped in rebound at 2 inches per second. The force needed for that isn't too hard to calculate with the spring rates and the right equation.
For compression I asked for 55% critically damped with an extra digressive curve. I'm using Tein H-tech springs (very mild drop, spring rates are I think 207 lbs/in front and 225 lbs/in rear).
You can also just give them the spring rates and a few words on how you use the car, but I'm pretty into this stuff.
It's approx 110 bucks a corner for the revalve. My shocks were used and needed a rebuild anyway. I just had the rears rebuilt to standard to save some money (rebuild is i think 70 per corner).
I also asked to have the internal bumpstops trimmed for the fronts.
I would have loved Ohlins, but I'm not sure how much longer I'll have this car and it's not in the budget.
- Andy
Old Dec 2, 2014 | 11:29 AM
  #39
kyoo's Avatar
kyoo
very happy with my bilsteins here!
Old Dec 2, 2014 | 11:52 AM
  #40
cristo's Avatar
cristo
Alliance Member
Your link indicates Bilstein Sports with JCW springs on a 2013 Cooper.
Is that correct?
Old Dec 2, 2014 | 11:57 AM
  #41
cristo's Avatar
cristo
Alliance Member
- Andy
Is that softer or harder than the standard valving on the Bilstein Sports?
does the extra digressive valving make it stiffer for low velocity inputs and less harsh for sharper faster bumps,
kind of like the idea behind the Koni FSD shocks?
Let me know how they compare to the Koni Yellows when you get them on!
Old Dec 2, 2014 | 12:02 PM
  #42
kyoo's Avatar
kyoo
Is that correct?
yep that's right. they were also custom valved. would be happy with them stock as well. bilstein's quality is top notch, not sure about konis. old but good read: http://farnorthracing.com/autocross_secrets18.html
Old Dec 11, 2014 | 11:01 PM
  #43
cesare's Avatar
cesare
- Andy
It'll be interesting to see how these Bilsteins feel after the revalve.
I prefer Bilstein dampers but to get adjustability for a reasonable price there really are only the Konis.
The only way to get adjustable Bilsteins are the PSS9/10 coilovers and those are a bit too pricey for me at the moment.
But i just have to get rid of the H-sport spring and stock shock combo...it's driving me batty!
Old Dec 19, 2014 | 06:01 PM
  #44
cristo's Avatar
cristo
Alliance Member
Had one other thought:
What about Bilstein Sport Shocks paired with the JCW red springs.
The high pressure gas shocks would bring them just about back to stock height.
Anyone try this? Anyone know what the spring rates are on the JCW springs?
Could possibly consider TSW springs with the Bilsteins since they only lower the
R50/R53 by 3/4 inch, or slightly less than that with Bilsteins.
Edit - I believe stock springs are about 165-170 #/in, JCW are about the same,
and TSW are 200 #/in linear springs.
Old Dec 21, 2014 | 08:06 PM
  #45
andyroo's Avatar
andyroo
I've never seen a real measurement of the JCW springs that I trusted.
I know that k-huevo has a good write-up on here of Bilstein + JCW springs.
I still haven't put my Bilsteins on...I'm slacking. Next week for sure though.
- Andrew
Old Dec 21, 2014 | 10:45 PM
  #46
cesare's Avatar
cesare
- Andrew
Sounds like a cool x-mas present to me
Old Dec 22, 2014 | 09:24 AM
  #47
cristo's Avatar
cristo
Alliance Member
Thanks - I remembered seeing that now that you mentioned it but it didn't
turn up on my recent searches.
Here it is:
https://www.northamericanmotoring.co...from-hell.html
I see that he notes the Bilstein Sports have spring perches that are
7 mm lower in the front and 5 mm lower in the rear, and he had the fronts
sent back to be revalved because they were just too harsh in original form.
Looks like Koni Sports + stock springs is staying at the top of the list for now,
followed by revalved Bilsteins and stock springs a distant second.
... Or Ohlins if a sack of money falls on me.
Last edited by cristo; Dec 22, 2014 at 10:41 AM. Reason: look (out), it's a bird, it's a plane, it's a sack with 1300 pounds of pennies!
Old Jan 29, 2015 | 10:07 AM
  #48
andyroo's Avatar
andyroo
Got my custom Bilsteins on and they are effing awesome. It's only been 2 days and they have a small "break-in" period where they soften up a bit but they are already fantastic. Better than my Konis for sure overall. I did trim the front internal bumpstops that they came with and it has helped the balance of the car a bit (more front grip).
The Konis rode better on smaller bumps, the Bilsteins not far behind but the Bilsteins are much better over big bumps. It's a much more solid experience and there is far less cringing taking place. I had to run the Konis near full soft (and that adjuster is mostly rebound) to be able to take the big bumps and that meant they were a little soft for handling. My custom Bilsteins do not have an excessive amount of rebound but do give me some decent digressive compression damping to make them so responsive. Good stuff.
It's still a MINI so the ride isn't "great" because there isn't a ton of travel. It is better than stock though. For me, this is pretty much the compromise I was looking for. The Konis are still good, and with the revalve on used Bilsteins I paid about as much as new Konis would have been. Starting from new it would have been more money.
They definitely lowered the front slightly. I should get an alignment now because of that.
I also hate doing strut installs on MINIs...this is definitely the last one.
- Andrew
Old Jan 30, 2015 | 06:26 AM
  #49
cristo's Avatar
cristo
Alliance Member
Thanks for the update. Good to hear it worked out splendidly.
I got Koni Sports and am keeping the oem SS+ springs, plus got an H-sport 19mm rear bar.
Just waiting for a warm-ish weekend to do the rear shocks and bar, and will probably
let the shop do the fronts in March, because
1 - I anticipate the fronts will be a pain to do at curbside in the cold.
2 - Annual inspection due then and it needs a driver strut mount to pass that
3 - Will probably not get enough pleasant weekend time to do both the rear and the front at home.
Old Jan 30, 2015 | 07:12 AM
  #50
andyroo's Avatar
andyroo
Yeah the rears are pretty straightforward. It's just always a battle with the fronts on these cars.
I have an extra pair of OEM front strut mounts...look like they're in decent condition. 15 + shipping?
- Andy
